02-08-2009, 08:12 AM
Batt Contactor to Starter Contactor Question
When using a 1/2" wide piece of brass or copper to connect the battery contactor to the starter contactor, how thick should the piece be? As a point of reference my drawing calls for a 4 AWG wire for this connection. It seems brass is the better choice over copper??
Thanks for the input.
02-08-2009, 08:35 AM
Cu is the better conductor of course. I cut up some coper fittings and flattened as a matl source. Needed to be wider-maybe 3/4 in. To leave enough around the holes.
Terry F.
RV 7A N457RV
250 hours and lovin it!
Southern Nevada EAA Chapter 1300 - www.eaa1300.org
Paid VAF 03/17
02-08-2009, 09:48 AM
The copper bar Van's provides for this is 1/2" wide by .063 thick. Two layers are required for that connection. It's shown in the wiring drawings.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
02-08-2009, 11:19 AM
If you can't find copper in bar form use a piece of copper water pipe squeezed flat in a vise.
02-08-2009, 04:17 PM
Get the Facts......
I work with Buss Bars all the time, not with DC Voltage though. I think you can find what you are looking for here. I definatly would not substitute pipe for buss bar.
Copper Buss Bars -
http://store.electrical-insulators-a...-barstock.html
Copper Buss Bar DC Ampacity -
http://www.copper.org/applications/b...mpacities.html
Michael Brown VAF #1458
Elkton, MD
Building RV-7
N227MB (Reserved)
Empennage Done
Wings Under Construction!
02-08-2009, 04:26 PM
Curious as to why you would not use a flattened piece of copper pipe? It is just as pure as copper buss bar and will carry the current.
02-08-2009, 06:20 PM
How many Amps?
True..... Copper is Copper and will carry current. How much current is the flattened pipe good for? At what point will it fail? I am just a firm believer in proper engineering, especially when it comes to airplanes.
Elkton, MD
Building RV-7
N227MB (Reserved)
Empennage Done
02-08-2009, 06:56 PM
Airplane workers....thanks for all the alternatives and info.
02-08-2009, 07:42 PM
Have used flattened copper tube/pipe for a bus more than a dozen times. How can anyone make a big deal out of that? As long as it's new & clean and not full of lime (used water pipe). You can always anneal it some mo'.
