Old 02-06-2009, 02:56 PM
burgundyja's Avatar
burgundyja burgundyja is offline
Default elevator push pull tube
does anyone know what grade the .750 elevator push pull tube is? i cut mine in half thinking it was a diffrent tube. i would like to just get one at a local shop. does it have a mill spec.
Mike Johnson
8A N484M
Old 02-06-2009, 02:58 PM
Danny7 Danny7 is offline
it should say in your preview plans. what kit are you working on? oh, an 8. sorry, i don't know, here is my 7 info:
for my rv7 it says in section 4 of the preview plans,parts index-
f-789 is AT6 035 x3/4
f790 is AT6-035 x 1 1/2
is that what you needed? AT6?
nothing special here...
Old 02-06-2009, 03:03 PM
burgundyja's Avatar
Default 8a
it is a 8a. the plans has a vans part number but it is not the same as what a metal shop uses.
Mike Johnson
8A N484M
Old 02-06-2009, 03:26 PM
isn't the first part of the vans number the material spec? AT6?
Old 02-06-2009, 03:36 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Section 5, I believe, of your build plans provides a key for the abbreviations Van's uses for its part numbers. IF I remember correctly, the AT6 = 6061 aluminum tube. 035 = the wall thickness. Check YOUR manual, though. I'm going off the top of my head.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 02-06-2009, 08:27 PM
rvbuilder2002's Avatar
Originally Posted by alpinelakespilot2000 View Post
Section 5, I believe, of your build plans provides a key for the abbreviations Van's uses for its part numbers. IF I remember correctly, the AT6 = 6006 aluminum tube. 035 = the wall thickness. Check YOUR manual, though. I'm going off the top of my head.
Steve is correct...Check chapter 5 of your construction manual.
The AT6 means (A)luminum (T)ube 6061-T6 X Diam X wall thickness
Scott McDaniels
Hubbard, Oregon
Old 02-06-2009, 08:59 PM
Noah's Avatar
Noah Noah is offline
Default Where to buy
I would get seamless extruded or drawn tubing
www.yardemetals.com
www.onlinemetals.com
www.mcmaster.com
all supply this, as well as Vans. Online metals will cut to length and specializes in small quantities.
There is probably someone closer to you in MN where you can get it, and save on the shipping premium due to the length, although now that I say that, this is the short one so shipping might not be bad.
Highest Regards,
Noah F, RV-7A
All men dream, but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men? for they may act their dream with open eyes, to make it possible. -T.E. Lawrence
