Originally Posted by alcladrv
I'm planning to install the newer style nose wheel fairing brackets. So, I need to fill in the axle holes. What's the best filler material to use with West System epoxy?
Flox and resin alone would not be a good choice to fill such large holes.
You should use a couple of layers of glass bridging acrossed the holes on the inside surface as a starting point.
Scott McDaniels
Hubbard, Oregon
