Old 02-02-2009, 10:46 AM
MS19087's Avatar
MS19087 MS19087 is offline
Default CH Grip stick: which button for PTT
I am using a CH Grip on my stick and am wiring it up right now. I always assumed I would use the trigger for PTT, however the INDEX button seems better for many reasons (comfort, position, etc) - I'm just curious . . . which button are other folks using for PTT???
Mark
RV-9A; Sold
RV-14A; Building
2020 =VAF= donor
Old 02-02-2009, 10:53 AM
craigvince's Avatar
craigvince craigvince is offline
I used the trigger.
Old 02-02-2009, 11:24 AM
DGlaeser DGlaeser is offline
Default Me too
Trigger for PTT
Small button under the trigger for A/P disconnect
Buttons on top are for my COMM 1 & 2 flip-flops
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 02-02-2009, 11:36 AM
Frank Smidler Frank Smidler is offline
Default Trigger works, don't use button
I wired the trigger for PTT and the button for flip flop. The tower must have thought I was incompetent since GRD could not respond to me since I hit the flip flow after contacting ground. Then as I held the grip in my left hand I noticed I was on the wrong frequency and tried several times with my right hand to push the radio button for flip flop and it would immediately flip back. Finally I realized I was holding the stick grip button. I haven't disabled the button yet but I am seriously considering it so I don't have a problem in the future. I will probably move the flip flop to one of the top buttons and eliminate the TPX ident button (doubt if I would use that function anyway).
Frank Smidler
N96FS, RV-6
Flying 1/11/09
1085 hr
2WI6 Stoughton, WI
Formally of Lafayette, IN
Old 02-02-2009, 11:40 AM
rvmills's Avatar
rvmills rvmills is offline
Default Me three
I have CH-4's in a -6. WIred up both sticks.
Trigger for PTT
Small button for AP disc
Inboard gray button for XPNDR ident
Outboard gray button reserved for smoke on/off (maybe). Radio flip flop sounds like a good idea too
Haven't had a problem with inadvertantly disconnecting the AP with the small button, since when on AP, I'm not gripping/moving the stick as I would be in the pattern...I could see where a radio flip-flop on that button might be an issue. Nice stick grip though!
Bob
Bob Mills
RV-6 "Rocket Six" N49VM
Reno-Stead, NV (KRTS)
Old 02-02-2009, 01:10 PM
sjjonesnz sjjonesnz is offline
Trigger - PTT
Small button - audio alert mute on AF3500
Left button - A/P (dis)connect
Right button - Com1/Com2 Swap on audio panel
Cheers
Steve
Auckland, New Zealand
Flying RV-7QB/ZK-NVS/Aerosport 0320/Dual AF3500s/PMA8000B/GNS430W/SL30/GTX327/TT ADIP II
Old 02-02-2009, 01:23 PM
carguy614's Avatar
carguy614 carguy614 is offline
Default trigger
Used the trigger for PTT and little button for AP. I like it
Regards,
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
Old 02-02-2009, 02:57 PM
odlee odlee is offline
Default Disabled the small button,
PTT is the trigger, the two side buttons are Ident and control wheel steering(this also doubles as an auto pilot disconnect.). The small button was a 430 com swap, which was easy to switch without knowing.
Have fun.
David
Old 02-02-2009, 04:27 PM
Trigger for PTT
The AP disconnect sounds like the best use for the small forward button. When I change the buttons around so it is not the flip-flop I'll probably reserve the small button for that purpose (when I get AP).
Frank Smidler
N96FS, RV-6
Flying 1/11/09
1085 hr
2WI6 Stoughton, WI
