Old 02-02-2009, 05:11 AM
SmittysRV's Avatar
SmittysRV SmittysRV is offline
Default Long Term Project
You know you've been working on your RV project for a long time when:
* You find pictures of your son where he has trouble seeing the top of the work bench and now his shoes are bigger than yours.
* You order new clecos and are shocked at how bad your original ones look.
* You see pictures of yourself when you first started the project and now you look like your grandfather, living proof that dinosaurs once ruled the earth.
* Your tail-kit drawings look like the Declaration of Independence.
Any takers?
Smitty
Old 02-02-2009, 06:03 AM
penguin penguin is offline
You start reading some of the stories on the newspaper that parts are packed in - it all seems so long ago.
There is a wasps nest around one of the engine mount tubes in the attic (lucky you discovered that in the winter)
You wonder what people are talking about when they say "take the plastic off first"
More to come I'm sure
Old 02-02-2009, 04:19 PM
Frank Smidler Frank Smidler is offline
You know it's been a long project when:
Your 15 year old daughter who helped rivet the top wing skins has now been out of college for almost 7 years and is married.
You had no gray in your early build pictures and now you only have gray.
Your youngest was only a toddler when you started and he had already soloed a glider and is old enough to get his power license when you finished.
Frank Smidler
N96FS, RV-6
Flying 1/11/09
1085 hr
2WI6 Stoughton, WI
Formally of Lafayette, IN
Old 02-02-2009, 04:53 PM
Don Jones's Avatar
Don Jones Don Jones is offline
Default Now this is.....
.....really depressing!
Don Jones
Technical Support Manager
Dynon Avionics
CFI-IA, AGI, IGI
RV9-A
Old 02-02-2009, 06:17 PM
cln1owner's Avatar
cln1owner cln1owner is offline
It is kind of depressing if you think about the whole project all at once, and how much more there is to do... focus on the task at hand. It's hard to believe that I'm 3 years into it already, with probably 3 to go... not long to some I know, but at least it's been fun.
Speaking of tasks, Smitty, you need to get out in the garage. I've passed you and now I don't know what to do.
Nate Benson
Ephrata, WA
RV9A/Slider N608MA
Flying
KitProject.com
"If you think you can do a thing, or think you can't do a thing, you're right." -- Henry Ford
Old 02-02-2009, 09:07 PM
longranger's Avatar
* The second grader that held the elevator skins open while you riveted stiffeners is now a freshman in college.... and you're still building the first tank.
RV-7 TU 904KM (reserved)
Construction Log
Old 02-03-2009, 04:39 AM
SmittysRV's Avatar
Sorry bout' that Nate. My wife just retired and well... You know where this is going.
Smitty
