Old 01-31-2009, 06:21 PM
avee8tor13 avee8tor13 is offline
Default GPS antenna location on fwd cowling - thoughts?
Thoughts on mounting the GPS antenna in front of windshield on upper cowling.
I saw one of the other builders do this. Looked pretty cool.
Old 01-31-2009, 06:44 PM
DGlaeser DGlaeser is offline
Default I mounted mine
Under the cowl forward of the firewall - can't see it at all, but works great!
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
Old 01-31-2009, 08:18 PM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
Mine is located on the forward fuselage skin between the canopy and the top cowling. It makes for a short coax run from the GPS!
Lucky for me my plane is white and the white antenna blends right in.
Good Luck
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 01-31-2009, 08:37 PM
Greg Arehart's Avatar
I did mine like Dennis - under the cowl on a small shelf I built. Works fine. I would only worry about this if you plan a metallic paint job, and even then, I'm not sure that the "metallic" part is really metal.
greg
Greg Arehart
N 7965A
Old 01-31-2009, 08:38 PM
AFulmer AFulmer is offline
Default What about mounting of WAAS antenna?
Does the WAAS GPS antenna require any special mounting method or location different from the "regular" GPS antenna? In other words, will it still work fine mounted under the upper cowl?
Would it work fine if mounted under a fiberglass access panel in front of the windshield as Dan Checkoway did?
Allen Fulmer
Wetumpka, AL
RV7 last 10%
Eggenfellner 3.0 Subaru
Old 01-31-2009, 08:40 PM
Default GPS cable length
I did not see any minimum length of cable or criteria to mount the antenna a minimum distance from the radio on the GNC300XL.
Are you saying you can mount the antenna 1 or 2 feet from the GPS radio and it would be ok?
Old 02-01-2009, 06:39 AM
pierre smith's Avatar
Default My buddy has a silver -4...
....with both the 496 antenna and the XM weather antenna mounted on a firewall mounted plate and they both receive very well, even with silver paint.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 02-01-2009, 08:13 AM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Default My opinion
It is like a wart.
Old 02-01-2009, 09:13 AM
AlexPeterson's Avatar
Allen, I can only speak for the 430w, but yes, there are some concerns. I don't recall the exact length, but there is a minimum coax length recommended. I don't know if one could simply coil up the coax or if physical distance from the comm antennae are also important. The test specified by Garmin for the 430w install is to power things up, and go to the satellite page of the 430w. Then, there are a series of comm frequencies to transmit on while watching the satellite page. I'm not so sure of just what is being observed, but the avionics guy who sat with me in the plane said my install was clean. I recall he told me that it is not uncommon to see indicated satellite signal strengths drop significantly during transmitting on certain freq's in certain installs.
All that being said, I suspect there are many experimentals flying with the 430w that did not have these checks performed. I wouldn't think Garmin made the requirement up for fun.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 02-01-2009, 09:48 AM
Christer's Avatar
Christer Christer is offline
Default GPS coax length
There is a minimum coax antenna length to maintain proper rejection to interference signals. This is about 1.5 dB - 6.5dB. If you are using RG400 coax (recommended) that is about 6.5 feet of cable minimum and 35 feet max assuming one connector at each end. You can coil it if you need to. The WAAS antenna also uses a TNC connector vs the BNC. If you get VHF interference there are also filters to help this (1575.42Mhz notch filter) but this is not a common problem.
Christer
Director of Maintenance, SteinAir Inc.
RV-8 Completed
