Old 01-31-2009, 07:41 AM
prkaye prkaye is offline
Default lower cowl question
For the lower cowl with the snorkel, the snorkel is at the front of a wide channel in the bottom of the lower cowl that ends on the aft side with a big opening where this portion of the cowl sits about 3.5" below the lower firewall flange. It looks from what I can see on the plans that this just gets left open? I.e. that you can look through the snorkel and see through out this wide gap in the back of the lower cowl. Is this correct?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 01-31-2009, 08:34 AM
Default lower cowl answer
Yes Phil this is correct. When I saw your Q I run down to the shop to look through the snorkel. That's exactly what I saw
There will be complex bracket in the middle of that opening. Will need some time and dozen tries to figure out how to do that bend. When filtered airbox is finished, nothing can be seen through that snorkel.
Old 01-31-2009, 09:22 AM
Ironflight's Avatar
VAF Moderator / Line Boy
Default The Snout?
I know this is just a terminology post Phil, and maybe I'm the only one that sees it that way, but I think that you're talking about the lower cowl with eh "snout" - right? The "snorkel" is a term usually reserved for the "smooth" lower cowl (with no holes or snout) because it actually has a "snorkel" that goes from the forward-facing intake up and to the front side of the engine where the air filter sits in the port-side cooling ramp.
But to answer your question directly, if you are talking about the standard cowl with a snout, yes - until you install the air box, you can see right out the back side on the belly. The exhaust pies and cooling air will exit through that slot.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-31-2009, 10:49 AM
rvbuilder2002's Avatar
Paul
I was also confused until Paul pointed out what you must be talking about.
This particular part of the cowl is normally referred to as the induction scoop.
Personally I would like to hear more about Paul's engine installation...if I could get exhaust pies to come out of my cowl exit, strafing runs on EAA chapter fly-in pot-lucks would be very popular
Scott McDaniels
Hubbard, Oregon
Old 01-31-2009, 11:21 AM
rvmills's Avatar
rvmills rvmills is offline
Personally I would like to here more about Paul's engine installation...if I could get exhaust pies to come out of my cowl exit, strafing runs on EAA chapter fly-in pot-lucks would be very popular
Exhaust pies would be a lot more fun than the ol' flour bags! I'm with Scott...Paul, how'd you engineer that!?! Nyuk, Nyuk!
Phil, sounds like you're moving along quite well!!
Bob
Bob Mills
RV-6 "Rocket Six" N49VM
Reno-Stead, NV (KRTS)
Old 01-31-2009, 12:01 PM
Ah, ok yes I was talking about the "snout" on my cowl for my carbeurated engine.
Thanks guys!
Phil
RV9A (SB)
Ottawa, Canada
Old 01-31-2009, 12:55 PM
gasman gasman is offline
I guess Paul's spell checker does not stand out when you are looking at the world through rose colored glasses..............
But then........... pies is spelled correctly..........
Old 01-31-2009, 01:20 PM
Ironflight's Avatar
I hate spell checkers......
Paul
Paul F. Dye
Old 01-31-2009, 03:30 PM
Paul
I wove em.................
Old 01-31-2009, 05:04 PM
Hawkeye7A's Avatar
Hawkeye7A Hawkeye7A is offline
Default Yup!
Paul
Spell checkers (or chess) does nothing for grammar. Or Grandma for that matter!
--Hawk Pierce
RV-7A Flying as of Sep 7, 2008
Phase One complete as of Nov 16, 2008
Finally painted!
600+ hours and lovin' every minute of it!
N728E
SE AZ
"I fly because it frees my mind from the tyranny of petty things."
--Antoine de Saint Exupery
