01-30-2009, 09:54 AM
Adding accesory plugs, cigar lighter....where & how to do it????
Hi all,
will want to plug in my new GPS on my side of the panel ( RV-9a) and also have a plug for the co-pilot to recharge their cell, or use an MP3 etc.
maybe a seat warmer at the most.
how much juice do I need? Should I just run them off the same circuit breaker, I think I have a spare 2 amp one.
..or should they be totally isolated? I plan to be using the gps as my main heading indicator, but just day VFR.
Also thought it would be good to plug in a solar battery charger that I could lay on the dash between flights.
thanks for any tips.
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
01-30-2009, 09:58 AM
Senior Curmudgeon
2 amp is not enough for seat warmer. I think it would work for the other items listed.
For the warmers, depends on the actual unit, but 7--10 amp per seat should work.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
01-30-2009, 10:05 AM
Originally Posted by flyboy1963
Hi all,
Perry,
I have a cigarette lighter plug near the glove box door wired directly off the battery and protected with a 10 amp circuit breaker. I use it to power a lap top in flight and anything else that can use 12VDC. I've also got a plug rigged up to connect to a battery charger. It goes a little over 10 amps sometimes but so far has worked just fine when needed.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
01-30-2009, 10:52 AM
Since I wasn't sure what devices would be plugged into it, I wired mine for 15 AMPS on a circuit all its own. I also placarded the plug to say 15 amp max. Not sure if I will always know the current draw of any device that might be plugged into it, but at least I'll remember how I wired it.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
01-30-2009, 12:02 PM
Check out Powerlet
I used a 15A breaker dedicated to a plug for all the above-stated functions.
However, I did not use a cigarette lighter socket.
There is something MUCH better. Its called Powerlet, it is similar in function to a cigarette lighter, but somewhat smaller, and a million times better quality. Positive snap in place, nice cover when not used, etc.
The Powerlet has become kind of a defacto standard for accessories in the motorcycle world. I think they come standard on BMW's.
So, while lots of accessory cables come now with cigarette lighter plugs, it would only take a few minutes to change the plug to something MUCH better.
I have one on my battery charger, my miniature portable air compressor, back-seat GPS cable.
I'll bet I'm not the only RV'er with a Powerlet installed...
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
01-30-2009, 02:30 PM
I wired mine with an in-line fuse coming straight off the battery. Keep it simple...if the fuse blows in flight, the plane keeps on flying.
Don Alexander
RV-8 Finished After 8 1/2 Years (2496 hours) of Loving Labor
Summerville, SC
01-30-2009, 09:52 PM
Powerlet
I also use a Powerlet plug. If you go to their website, you can get an adapter that will allow a regular cigarette-lighter plug to be inserted into their female plug. This eliminates the re-wiring. I also stole an idea from Tony Spicer and installed a Powerlet plug inside the dip-stick door that allows the battery to be charged from outside, without installing a thru-hull connection.
Bill Newkirk
Flying RV-3B
