Old 01-29-2009, 04:17 PM
greight greight is offline
Default Can a CHT be too cold???
I have been having a high CHT problem on my #1 cyl of my Superior IO-360. I found that the problem was that I had too much of the front side of the cyl covered with my baffle and have now trimmed it down, quite a bit. Now I have the opposite problem. My #1 cht is quite a bit colder than the others. Is it a problem to have one cyl too cold? Should I build up my baffle to get all the CHTs about the same, or is it OK to have one cold cyl? It is about 30 degrees cooler than than the rest.
Old 01-29-2009, 04:27 PM
Mathew Sharp's Avatar
Mathew Sharp Mathew Sharp is offline
What literal temperatures are you seeing?
What has been your maximum CHT differential?
Do you see one cylinder cooling much faster than the other?
Matt
Electronics International Inc.
Sales/Support
63296 Powell Butte Hwy
Bend, OR 97701
www.buy-ei.com
support@buy-ei.com
877-318-6060 Ext 113
