Old 01-29-2009, 06:26 AM
Crossair Crossair is offline
Default Parallel valve cylinders on an angle valve case and crank.
I have an IO540 heavy crank and case (IO-540-K1A5 300 hp) but has parellel valve heads on it. Does anyone have information on this setup?
Old 01-29-2009, 09:27 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF!!!!
David, welcome to the forums.
I would suggest contacting Barrett or Mattituck, both are regular followers of the forums.
Either firm is just a click away------look to the ads on the left of the screen, towards the top.
Good luck in your search.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-29-2009, 09:51 AM
rocketbob's Avatar
Might want to talk to Lycon or Performance Engines. I remember one of the two taking the big-journal cranks like you have and making a stroker out of it, by moving the journal center out and grinding them down to use light-crank rods.
I think you have the best of both worlds at the expense of weight. The K-series also has the big oil pump, which is desirable. The K-series also has a tuned induction system, but its heavy.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 01-29-2009, 11:50 AM
Vern's Avatar
Vern Vern is offline
Default Angle valve cylinders
I have a set of serviceable cylinders for sale if needed.
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 01-29-2009, 12:06 PM
rgbewley rgbewley is offline
We have built several big main parallel head 540s in the past. The big main crank assembly weighs approximately 20 pounds more than the small main 540crank but is fine unless the engine has been stroked. I wouldn't think a stroked 540 would be the type of engine you'd want in an RV due to reliability/longevity issues.
As Bob mentioned the -K series (piccolo tube) sump is quite heavy, at least 12 lbs heavier than a stock updraft sump or our cold air induction and will be rear induction, so you will want to look at the sump setup. That is a pretty easy swap if you need to make a change for use in an RV.
The only other thing you might want to verify is the compression ratio. We talk about this all of the time, but you will loose TBO in a high compression engine.
Hope you find this information helpful.
Rhonda Barrett-Bewley
