Go Back   VAF Forums > Avionics / Interiors / Fiberglass > GPS
Old 01-28-2009, 09:22 PM
boom3's Avatar
boom3 boom3 is offline
Default ARINC 429 shield grounding
I've been reading about ARINC 429 and it says to use a twisted shielded pair with the shield grounded on both ends. To what? The Dynon HS34 for example really doesn't have a great place to ground something. Do you make your own local ground? Do you intercept the primary ground wire?
Thanks!
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
Old 01-29-2009, 04:51 AM
f1rocket's Avatar
f1rocket f1rocket is offline
I believe what they mean is to use the ground point for the radios. On most avionics wiring diagrams, you'll see that all the grounds for the radio are tied together and gounded in one location. That's to prevent ground loops within the radio circuits.
I've always thought that you ground data circuits on the end that is receiving the signal, not the end sending the signal. Grounding both ends can create a ground loop unless the two devices sharing the data line are grounded at the same location.
I'm not an electical expert so take my thoughts with a grain of salt. Maybe other experts who do this for a living can comment further.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
Old 01-29-2009, 08:33 AM
boom3's Avatar
I agree Randy, in most of my wiring experience with shielded pairs, only one end of the shield is grounded to prevent a ground loop.
Since I've never wired an ARINC 429 circuit, I thought it be worth asking about.
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
Old 01-29-2009, 09:03 AM
Rainier Lamers Rainier Lamers is offline
ARINC specification 429 makes specific mention on page 76 (part 1) that "Shields to be grounded on both ends of all breaks". Breaks being nodes in a multi-drop environment (one TX to multiple RX).
I'm going to stick my neck out and recommed that your assumption above is preferable IN THE ENVIRONMENT OF A VERY SMALL AIRCRAFT.
That is bold because it means there are no long cable runs for the ARINC signal. This changes the playing field a bit.
Avoidance of unnecessary ground loops is of prime importance in my experience if you want a complex avionics panel that works without trouble.
Even more so since the ARINC signal is a differential signal and thus is not referenced to ground.
Rainier
CEO MGL Avionics
Old 01-29-2009, 09:42 AM
f1rocket's Avatar
On my previous Rocket, I had an ARINC 429 interface between the autopilot and the EFIS. If I recall correctly, I ran unshielded 22 AWG wires and they worked fine. On my current build, I plan to run shielded twisted pairs grounded at the AP head FWIW.
Randy Pflanzer
Greenwood, IN
Paid through 2043!
Old 01-29-2009, 10:09 AM
boom3's Avatar
Thanks for your replies guys!
Since we're definately talking short runs here, maybe 2 or 3ft, I'm comfortable in just grounding the shield on 1 end.
On my next project, a slow build C-17, I'll probably have to reconsider.
Jeff Bloomquist
Sumner, WA
PP-ASEL, IR
RV-7A
Flying
1150 Hours
