Old 01-28-2009, 05:36 PM
lostpilot28's Avatar
lostpilot28 lostpilot28 is offline
Default PMag switchology
I'm sitting out at my hangar and was attempting to set the timing on my P-Mags. I have my S700 2-10 switches wired according to the Aerolectric connection, with the P-lead going to pin 2 and ground in Pin 3 (on the switch). I then have 12V system power going to pin 4 and out to the P-Mag on Pin 5. The problem is, in this configuration the P-lead stays grounded when the switch is moved to the middle position. Also, 12V power is not "on" at the P-Mag in this position.
So, I've been trying to figure out how to configure the back of my switch. I have no "ground maintenance" mode...I just want to set it up so that "Down" is P-lead grounded, middle position is P-lead ungrounded with the P-Mag running on it's own power, and Up is when the P-Mag is running on System Power.
I don't think the Aerolectric connection is right in the Z-13/8 diagram. Anyone have any suggestions?
Sonny W
Boise, Idaho
RV-7A Flying!
Old 01-28-2009, 08:12 PM
Ken Ken is offline
Sonny,
See page Z-9 Appendix Z Aeroelectric Connection terminal locations. Note the difference between fast on and screw connections.
Maybe this will help
Ken
Old 01-28-2009, 08:14 PM
Ken Ken is offline
Also page 11-18 Figure 11-14 should help.
Ken
Old 01-28-2009, 08:27 PM
Thanks Ken,
I've been through a few iterations with connecting these things that I'm not sure if I've tried that, but I think that's the original way I had them hooked up. I'll certainly try it again tomorrow when I'm back out at the hangar.
Sonny W
Boise, Idaho
RV-7A Flying!
Old 01-28-2009, 10:10 PM
petehowell's Avatar
Default Diagrams sent
Sonny,
Check your E-mail - I sent some diagrams.
Pete
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 01-28-2009, 10:18 PM
Got them! Thanks Pete.
Sonny W
Boise, Idaho
RV-7A Flying!
Old 01-28-2009, 10:56 PM
SMO's Avatar
SMO SMO is offline
Default Me too
Sonny, when you get this sorted out will you post the result? I have a pair of Pmags still in the box and will be putting them on in a couple of weeks. Also have the same switches, and was planning to follow the same Aeroelectric diagram.
Mark Olson
1987 RV-4 Sold
2003 Super Decathlon - Sold
F1 EVO Rocket, first flight May 31/14
First in line for the Sonex JSX-2T kit
Old 01-29-2009, 10:20 AM
erich weaver's Avatar
Be aware that the switch wiring diagrams in the AeroElectric Connection doument are not always correct for Carling switches - at some point in time, right side pins were swapped with left side by the factory (nice, eh?). This was the case for me, and it messed up my wiring til I figured out what was going on. Bob has acknowledged this in his forum, but Im not sure this has found its way into the 'Connection yet. Verify the pins do what they are supposed to with a multimeter before installation!
erich
Old 01-30-2009, 03:31 AM
Chris Byrne Chris Byrne is offline
I did have mine wired as per Bob. Went back to the wiring diagram from Emagair for simplicity. My power comes straight from the main bus through a CB (no switch), so it is basically wired as per their Emag wiring diagram.
I test the generater in the Pmag periodically by switching off all the power to the Pmag and slowly closing the throttle at the end of the flight. You can really only test one Pmag per start up this way but I dont find it necessary to test this function every flight.
This wiring system makes it easy to get into the setup mode. Previously (Bobs wiring) I had to run a seperate temporary ground wire (or instal another switch).
I find the factory wiring much better.
Old 01-30-2009, 05:50 AM
Steve Sampson Steve Sampson is offline
Default Keep it simple.....
If you still have not wired those P-mags up, you might want to give consideration to the way I have done it, which is essentially the E-mag way, but each P-mag controled by just one 2-50 switch, so it is ergonomically almost identical to standard mag switches.
For details see here.
When I looked at the Aero Electric approach it appeared to be trying to make extra, unnecessary complexity, but I forget the details. I think they changed their minds at least once after talking to E-mag who might know something about it.
Steve
G-IKON Build log here , or Index to blog here.
RV4 #4478 - Flying since 16th June '08. First flight video here.
Circuits at my 1000' strip.
