Old 01-28-2009, 08:05 AM
WenEng WenEng is offline
Default Can you start an IO360 without prop?
I have a burning desire to fire up a mid time IO360 before I have a prop. What is the conventional wisdom of running the engine for a minute or so without a prop? Someone told me it needs a prop to be balanced, but I'm not sure about that, having experience with auto engines but not aircraft. Any A&Ps out there that can help answer?
2nd question..
The starter teeth look partially engaged with the flywheel teeth when I received the engine. I haven't powered the starter yet, but wondering if its just in need of lube. For all I know, the previou owner had the starter out and powered it up off the engine, leaving the shaft extended. Just curious if anyone has seen that before. I should probably just power it up for short spin to see if it retracts. Just a new guy thinking outloud here
Wendell VAF#1832
RV-6A 3/4 done...N48JE Reserved
Build site: www.mykitlog.com/weneng
Donated to VAF in 2020
Old 01-28-2009, 08:14 AM
Vern's Avatar
Vern Vern is offline
Default Don't start that engine!
..without a prop or a test-club (a dummy prop used in engine test cells.)
This is not a car engine in a junkyard!
Vern Darley
Awarded FAA "The Wright Brothers 'Master Pilot' Award"- for 50 years safe flying
RV-6A N680V / RV-10QB N353RV
Luscombe 8E N2423K 50+years
Hatz Biplane N2423Z soon to be birthed
Falcon RV Squadron Founder
KFFC Hanger D-30
Peachtree City, Ga
770 310-7169
EAA Technical Counselor #5142
EAA Flight Advisor #486336
ATP/CFI/A&P/DAR
Old 01-28-2009, 08:53 AM
2nd question..
Auto engines have a fly wheel and can be run without any other load although will over speed very easily if you're not careful.
The Lycoming has no fly wheel and probably will over speed if started with no load. I would not do it, especially if just to see it it will run.
The starter being partially extended is normal after it is powered with no engine start. When the engine starts it will retract.
RV-12 Build Helper
RV-7A...Sold #70374
The RV-8...Sold #83261
Old 01-28-2009, 09:13 AM
Brantel's Avatar
Brantel Brantel is offline
Dude no way!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 01-28-2009, 09:43 AM
rv72004 rv72004 is offline
if you only idled it, what could be the problem? only asking...........
EJ
RV7 flying
xp360, CS, All Glass cockpit
Old 01-28-2009, 09:50 AM
allbee allbee is offline
What if??? Yup, what if it went to full throttle and... you couldn't shut it down. In the end it's your call. I won't do it.
Old 01-28-2009, 09:54 AM
N941WR's Avatar
N941WR N941WR is offline
Two things, the staring sequence will/may cause the engine to over speed and second, the prop works like a flywheel to dampen out the power pulses.
Just wait, it won't be long now.
I never even connected the power lead to the starter until I was at the airport just to avoid an accidently engagement.
Don't do it w/o some type of load on your engine. Remember, when you start up your car engine it has a flywheel attached to dampen things out, you won't even have that.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-28-2009, 01:09 PM
Default Starter explanation is what I thought. Thanks.
On the engine, I am cautious enough and old enough to ask around. My burning desire to start the engine is the same burning desire to finish the -6A and fly. All in due time, for sure.
Thanks.
Wendell VAF#1832
Old 01-28-2009, 01:16 PM
hudgin hudgin is offline
The fly wheel on a car engine is very similar in weight to the flywheel on the Lyc if the car engine is automatic. So theroetically you could do it. As was said earlier the starting sequence will give cause to most likely over rev the engine even if for a second. Another thing to consider is that the IO 360 series most likely has an internally dampened crankshaft. Running the engine without the weight of a balanced prop will damage the crank. I short I would not recommend it.
Old 01-28-2009, 02:01 PM
CESSNADON CESSNADON is offline
The torque converter on an auto engine is part of the flywheel..Most likely, the aircraft engine will not start without a club as there will not be enough energy stored in the flywheel to get the pistons over tdc....may backfire and damage some internals too. Definately not worth the risk to try....
