Old 01-27-2009, 07:50 PM
avee8tor13 avee8tor13 is offline
Default GNC300XL antenna cable - what cable can I use?
All,
Do I have to use the Garmin recommended antenna cable for the GPS and COM or can I use after marker cable. Thank you.
Old 01-27-2009, 08:25 PM
Mel's Avatar
Mel Mel is offline
Default Others will disagree,
but I have been running a GNC250 and 250XL (basically the same radio as the 300XL) for quite a number of years using good quality RG-58 and have had no problems whatsoever. It is perfectly fine for the lengths we use.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 01-27-2009, 09:56 PM
SteinAir SteinAir is offline
RG-58 will work, most professional shops will only use RG-400, or sometimes RG-142.
Stein
