Old 01-27-2009, 03:19 PM
alpinelakespilot2000 alpinelakespilot2000 is offline
Default 22AWG wires in red terminals
Whenever I crimp a 22AWG wire into a red terminal I'm always thinking: "not much wire for the terminal to grab onto. I wonder if this thing is going to hold."
Is it good (or not good) practice to strip extra insulation away and double over the wire before inserting it into the terminal and crimping it? It seems like the terminal has more to grab onto doing it this way, but perhaps somewhere there is a prohibition against doing this?
Any thoughts? Thanks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 01-27-2009, 03:26 PM
Lycosaurus's Avatar
Lycosaurus Lycosaurus is offline
Originally Posted by alpinelakespilot2000 View Post
...Is it good (or not good) practice to strip extra insulation away and double over the wire before inserting it into the terminal and crimping it? ...
Steve,
I would do a pull test on the connection. If it does not pull out, you are fine, you may want to use heat shrink tubing to provide some support for the wire itself (depending on the application).
Adding extra wire (folding over) will not buy you any additional strength if the pull test passed in the first place.
... those are my thoughts.
Alfio
RV-9A Ottawa, Canada
First flight Dec. 18, 2008
> 1,000 hrs tach.
Old 01-27-2009, 05:19 PM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
I have no idea is the aviation wiring bible is for or against the practice, but I have been doing it for a lot of years, and never had an issue.
As was stated, pull on the finished connection------all of them.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-27-2009, 05:55 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
I don't know which crimps you use, but I use the type that have an additional crimp on the wires insulation. I get these at the local FBO.
They are a pink color & see thru.
L.Adamson
Old 01-27-2009, 06:30 PM
GAHco's Avatar
GAHco GAHco is offline
Post Use Amp PIDG or Equivilant Terminals.
The price for the terminals are reasonable.
You should not need to fold your wires with the correct terminals.
Tech Pages http://www.gen-aircraft-hardware.com...ing&splice.pdf
The cost for the tool (p/n 59824-1) to do the crimp on the wire and the insulation at the same time properly is "Not Cheap" nor will a cheap one do that specific job as well.
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 01-27-2009, 07:34 PM
I have Stein's crimper and Stein's pink terminals, so I'm good to go on the quality part. It's pretty hard to make a bad crimp with them, and I have pull tested every single crimp I've made.
My only question was whether there is anything to gain by doubling the wire over before crimping and whether it is even "permissable" to do so.
Steve M.
Ellensburg WA
Old 01-27-2009, 08:51 PM
gasman gasman is offline
I don't think you have a problem with doubling the wire. "PERMISSIBLE" is up to you.
I had to think long and hard before I decided to SOLDER all of my terminals. I use the crimp on connectors but cut off the insulation, insert the wire and give an easy crimp. Then solder, not to wick past the barrel. Then it is covered with a layer of heat shrink for support. Right or wrong, I feel good about my connections and have had no problems.
Having said that, everyone seems to get by just fine with just a good crimp and a pull test.
A bad crimp will create resistance and will change the reading of any gauge that reads resistance.
Old 01-28-2009, 05:31 AM
ronschreck's Avatar
ronschreck ronschreck is offline
Stand back! You are about to get buried in replies, all telling you the many reasons you should not have soldered your terminals.
Ron Schreck
IAC National Judge
RV-8, "Miss Izzy", 2250 Hours - Sold
VAF 2021 Donor
Old 01-28-2009, 06:43 AM
FredMagare FredMagare is offline
Steve,
In regards to doubling over the wire - logically speaking, you're not weakening the wire where the strands enter the insulation. So long as the crimp grips and the barrel holds, I'd say you're ok to do that.
On a side note: I went to great pains to calculate my wire needs and set about purchasing 25ft of 22AWG, 15ft of 20AWG, 22ft of 18AWG, 10ft of 16AWG, etc. For those who are getting ready to wire their aircraft - may I suggest you consolidate your wiring? Why buy 22AWG, 20AWG, and 18AWG in various lengths when 18AWG will handle all of those needs? We don't have so much wire in our aircraft that the extra weight would be even three pounds additional for upsizing a few wire runs. Purchase a couple of spools of 18AWG and 12AWG. That should be satisfactory to carry the majority of your electrical needs with the exception of some of the wiring on the firewall side.
Fred Magare
GySgt, USMC (Ret.)
PP-ASEL, A&P
Frederic.magare "at" gmail.com
RV-9A Firewall Forward
[Engine purchased]
Old 01-28-2009, 06:50 AM
Mel's Avatar
Mel Mel is offline
I never use anything smaller than 20 AWG simply for the ease of using it.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
