Old 01-27-2009, 07:29 AM
RickWoodall's Avatar
RickWoodall RickWoodall is offline
Default Manual trim cable adjustments at tab end
Anyone know of a good site detailing the adjustments of the manual trim cable. Its routed, tail is final installed and just trying to adjust trim to spec'd travel. We have adjusted the cable several times, threaded it out/in, spun the clevis end in and out and still having trouble getting it just right. Cant seem to find good build site detail on how/if others have had trouble with the fine adjustments and what we might be doing goofy. Any suggestions welcome...
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dual dynon hdx with a/p. 900+ hrs in 8 yrs flying.
Flew to Osh 11,12,15,17,19. SNF 2013. West to Cali /Washington/Vancouver/crossed the Rockies north to Red Deer east to Moosonee and over to maritimes. South to Jekyll Isl, cedar key, and Key West etc. 6 trips and 17 islands of the Bahamas. Flown turtles and dogs for Pilots n Paws too. Love our Rv's
Old 01-27-2009, 11:32 AM
Hawkeye7A's Avatar
Hawkeye7A Hawkeye7A is offline
Default Here's what I did
I posted a similar question some time ago and after melding all the responses, this is how I set mine, although on a -7A. You need a bit more up trim than down so I first determined how many turns were available on the knob; ~10 turns stop to stop. The proper ratio of pitch up (tab down) to pitch down (tab up) was 7:5. From the two stop points I kept adjusting until I had ~35mm tab down (pitch up) and ~25mm tab up (pitch down). This measurement was taken from the trailing edge of the left elevator to the trailing edge of the trim tab. As I was also told during my question and answer series, the amount of trim you will actually use during all flight regimens will not amount to more than 1-1/2 turns of the knob TOTAL! (If that much) This proved to be true. As with many other things during the build, the anxiety of anticipation is far worse than the actual task. Hope this helps.
--Hawk Pierce
RV-7A Flying as of Sep 7, 2008
Phase One complete as of Nov 16, 2008
Finally painted!
600+ hours and lovin' every minute of it!
N728E
SE AZ
"I fly because it frees my mind from the tyranny of petty things."
--Antoine de Saint Exupery
Old 01-27-2009, 07:19 PM
cwreeves cwreeves is offline
Thumbs up Manual Trim
I measured the total travel of the cable between the knob and cable base (where it mounts to the plate) divided in half, moved the knob to match the 1/2 distance, set the trim tab to neutral and adjusted the clevis to match. Works just fine.
Charlie
