Old 01-26-2009, 09:37 PM
lostpilot28's Avatar
lostpilot28 lostpilot28 is offline
Default Wing spar bolts - Ugh!
OK, so in my haste to get my wings mated, I overlooked the fact that lower bolts need washers under the head of the bolt, not the nut.
Question #1: I've done a search and found numerous ways that folks have removed the lower bolts, but does anyone have a "best idea" to make this job easy? I'm considering buying a soft brass dowl (smaller diameter than the bolts) and using a rivet gun to gently tab the bolts out from the threaded side. Maybe also use a pry-bar under the head of the bolt to assist (fulcrum of wood to protect the center-section. Anyone have a better idea?
Question #2: How does one torque the nuts that are barely accessible because of the gear weldement?
My sincere appreciation for any advise offered!
Sonny W
Boise, Idaho
RV-7A Flying!
Old 01-26-2009, 10:46 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Default You're not alone
I did the same thing when I mounted my wings a couple of months ago. At least I caught the error before I put in the 4 small bolts.
I called Vans and they said not to worry as long as I put the washers on the forward side to insure that the nuts would not bottom out. I sprayed some LPS-3 under the head of the bolts since you have the turn the bolt head to get them tight.
I torqued mine to the high end of the torque range since I was turning the head and not the nut. It's pretty darn hard even getting a wrench on the nuts, let alone a torque wrench. If I remember correctly, I used a screw driver jammed under one nut on each side 'cause there was no way to get a wrench on the nut.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 01-27-2009, 04:20 AM
thinkn9a thinkn9a is offline
Default any chance a short wrench would help?
I ended up going to SEARS and getting a SHORTY wrench,.. then grinding off some of the sides,... to get it to fit into the tight fit between fuse and nut,.. of course this is 9A,.. so don't know if or how it would translate for you
Wallace & Marietta Goodloe
9A -QB
N211LV
Phase 2 has started!
Thanksgiving time, is dues time for us
Old 01-27-2009, 08:36 AM
RV7ator RV7ator is offline
Default Leave 'em Be
Sonny,
Don't mess with it. Your nose-dragger mount replaces some need for washers to prevent bottoming of the nut. If all's snug, you'll only risk more damage under the head trying to "correct" it.
John Siebold
Old 01-27-2009, 08:42 AM
Originally Posted by RV7ator View Post
Sonny,
John Siebold
Hi John,
Thanks...I have to back them out a little bit, though because I don't have enough room to get the nut on. Doh! I like the idea posted above about lubing under the bolt-head so as not to cause damage to the center section.
Regarding torquing the head of the bolt, should I calculate the drag first? I'm guessing it'll be pretty high.
Sonny W
Boise, Idaho
RV-7A Flying!
Old 01-27-2009, 08:44 AM
Thanks, Rick...The 1/4" bolts were definitely a tighter fit on mine. I will have to back them out slightly to get the nut on, but I don't think I'll be taking them all the way out.
Sonny W
Boise, Idaho
RV-7A Flying!
Old 01-27-2009, 12:37 PM
RScott RScott is offline
Ideally, you torque the nut, not the bolt. To torque bolts properly, measure the drag on the bolts without the nuts (or the nuts can be loose). If the nuts don't turn freely, measure the drag on them, too. You will probably need a beam type torque wrench to do this. Add those to the torque spec. I have had nuts showing as much as 15 inch pounds drag, when the spec was less than 30 pounds, so if I just torqued to spec I would only have half the designed torque.
Richard Scott
RV-9A Fuselage
1941 Interstate Cadet
Old 10-19-2009, 08:09 PM
Lionclaw's Avatar
Lionclaw Lionclaw is offline
I made this dumb mistake tonight. Forgot the washer under the head of one of the lower bolts. It took about an hour with a wrench turning and pulling at an angle to get it back out. Hopefully I won't make the same mistake again.
Is the one washer sufficient for each bolt? It seems to tighten before bottoming out, but it's hard to be certain considering the bolts are in so tight to begin with.
Andy Compton, PhD EE
RV-10 - #41414 (building)
RV-9A - N643AC (built,flying,sold,missed)
My blood and sweat, the Wifey's tears
Old 10-19-2009, 09:23 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
One washer is all that is required... that is on the head side.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 10-20-2009, 07:22 AM
DGlaeser DGlaeser is offline
Default Those bolts are in shear...
So torque is not super critical. If you are reasonably close, and you have threads showing (smoke and mirrors may be required to see :-) then you are good to go.
I also forgot to put the washer under the head. I concur with RV7ator, trying to remove them is more risk than leaving them alone.
One of my hangar mates (another 7A) has a ground down open end wrench that he let me borrow to hold the nuts. Not easy, but possible.
I super-glued the nuts to a strip of aluminum to hold them in place until the bolt got started in the nut.
Dennis Glaeser CFII
Rochester Hills, MI
RV-7A - Eggenfellner H6, GRT Sport ES, EIS4000, 300XL, SL30, TT Gemini, PMA6000, AK950L, GT320,
uAvionixEcho ADSB in/out with GRT Safe Fly GPS
