Old 01-26-2009, 12:19 PM
lucaperazzolli's Avatar
lucaperazzolli lucaperazzolli is offline
Angry conical gusset @ front baffle
I find terrible to build this item for the engine baffle kit (as per plans).
Tons of sheet metal trashed ....
Somebody has an idea (photos welcome) ?
Luke
Trento, northern Italy
RV-8 QuickBuild, Catto 3 blade Prop, YO-360-A1A. Status : I-LUKE is Flying - 400 h. and counting
http://www.rv8.it
CrewRV8 team leader
https://youtu.be/VhAkhuqZMQA
https://www.youtube.com/watch?v=he9AFHRO1OY
=VAF= 2020
Old 01-26-2009, 12:40 PM
Brantel's Avatar
Brantel Brantel is offline
Not going to make you happy, but I found these easy to make.
What I did was cut me out a construction paper template to get the overall dims correct. I just eyeballed them and marked the paper and cutout the template. Used the lower cowl inlet radius to set the overall radius of the large side of the conical.
Then I used the template to mark the sheet of alum. Cut that out.
Then I took the part to a vice with smooth jaws. I marked the center of the tight end of the conical and kept that point constant in the vice. I just closed up the vice jaws to about 1/8" gap.
I kept bending the part a little at a time while moving the large end of the conical all the while keeping the tight end in the same place on the jaws.
Move slow and a little at a time. Once you get it so far, you can just take your hands and form it the rest of the way.
Do not get too agressive or you will end up with little straight sections.
Hope this helps!
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 01-26-2009, 12:57 PM
Default conical gusset
Thanks a lot Brian,
your photos are great !
Tomorrow I'll try again
Luke
http://www.rv8.it
CrewRV8 team leader
=VAF= 2020
Old 01-27-2009, 08:19 PM
Greg Arehart's Avatar
I'm not sure about your setup, but I did not bother with these. I just cut my baffle seals to fit. Seems to work just fine after 33 hours.
greg
Greg Arehart
N 7965A
