Old 01-26-2009, 06:28 AM
flickroll's Avatar
flickroll flickroll is offline
Default Intercom Wiring Run
I need to run shielded intercom cables to the rear passenger in my -8. I would like to keep the wires completely hidden. One possible route rearward is the wires tucked inside the right hand pilot's switch/circuit breaker panel. This would be the most convenient but I worry about picking up noise from all of the beakers and switches. How have other -8 builders routed these cables? Thoughts/comments? Thanks
Jim Shannon
RV-8 N52VV
Charlottesville, VA
AFS 4500 EFIS & 3400 EFIS/EM
G430W - SL30 - G327 - G696 - G240
TT DigiFlight II VSVG w/pitch autotrim
VP-X Pro
Old 01-26-2009, 07:06 AM
N208ET N208ET is offline
Default right console
is where I ran mine, along with most of my other wires.
Randy
8A Finishing, Wiring
Old 01-26-2009, 07:48 AM
dedgemon's Avatar
dedgemon dedgemon is offline
Default Under the floor
along the left side. Then up along the front of the bulkhead where the cross brace is attached. I put the jacks up near the longeron just behind the crossbrace.
David Edgemon
RV-9A N42DE
RV-8 N48DE
whats next ??
Track me!
Old 01-26-2009, 09:12 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Originally Posted by flickroll View Post
I need to run shielded intercom cables to the rear passenger in my -8. I would like to keep the wires completely hidden...... Thoughts/comments? Thanks
This is one of those deals where among other things the builder has to decide where he prefers the pax jacks be located. The wires completely hidden, this wiring run is about as simple as it gets. The intercom IS attached to the right side console. Though not flight tested yet, I'm not too worried about interference issues because Stein made up the shielded intercom harness for me and his attention to quality and detail is legendary.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 01-26-2009, 10:14 AM
grover grover is offline
Default rt side
right past (through) the cb panel, under the rear armrests. no issues.
james kleen
savannah
RV8sp
- RV3
