Old 01-25-2009, 05:39 PM
flickroll's Avatar
flickroll flickroll is offline
Default Dynon Carb Temp
I am finally getting my avionics in the airplane and today powered up the EMS-D120 for the first time with all of the probes connected. Everything is indicating properly except the carb temp. All of the CHT's and EGT's and the oil temp were reading about 57 degrees F which was about the ambient in my hangar. The carb temp is reading about 45-50 degrees high. It was indicating around 105 deg F. I stuck the probe in ice water and it dropped to about 80, and then put a heat gun to it and it climbed up into the mid 100's before I took the heat gun off of it. So the probe is working except it reads high. I suspect a bum probe but thought I'd post here to see if anyone has had this problem, or if anyone has additional ideas to troubleshoot. I have the probe with the white/black wires which do not require the +5v excitation. Thanks...
Jim Shannon
RV-8 N52VV
Charlottesville, VA
AFS 4500 EFIS & 3400 EFIS/EM
G430W - SL30 - G327 - G696 - G240
TT DigiFlight II VSVG w/pitch autotrim
VP-X Pro
Old 01-25-2009, 05:58 PM
jthocker's Avatar
jthocker jthocker is offline
Jim
You probably have the wrong sensor selected. Try the other ones and I'll bet that will fix it.
Regards,
Jon Thocker
Habitual Offender
RV4, RV4, RV6A, RV8, RV8, RV8,RV8, RV8, RV8, RV12
Old 01-25-2009, 06:07 PM
Brantel's Avatar
Brantel Brantel is offline
Did you set the probe type in the setup correctly? There are three to pick from.
Brantel (Brian Chesteen),
RV-7/TU, #72823, N159SB
Track N159SB (KK4LIF)
Old 01-25-2009, 07:16 PM
flickroll's Avatar
Brian, I bet that's it. I did not even think about the probe selection page. I'll check it tomorrow. Thanks!
Jim Shannon
RV-8 N52VV
Charlottesville, VA
VP-X Pro
Old 01-26-2009, 05:49 PM
flickroll's Avatar
What a bonehead I was. Today I changed the sensor type to the correct one and now the carb temp reads the same as the CHT's/EGT's/Oil Temp. Thanks for the advice....my only excuse is that it had been a long day and I was anxious to power it all up
Jim Shannon
RV-8 N52VV
Charlottesville, VA
VP-X Pro
Old 01-26-2009, 06:24 PM
mannanj's Avatar
mannanj mannanj is offline
That's usually when you let the smoke out of the wires!
LAUS DEO
Mannan J.Thomason, MSGT. USAF (RET)
VAF788
"Bucket List" checkoff in progress!
Old 01-28-2009, 08:18 AM
Scott Hersha Scott Hersha is offline
Default Carb air temp
I also have had trouble with my Dynon carb sensor. Mine doesn't seem to work at all. It indicates -45 at the top with a green band below, a yellow band near the bottom, and then green band again. I've tried switching the wires, thinking I the +/- wrong, but that didn't help. I did try the different sensor options on the setup program too, but so far nothing has helped. I have the probe that doesn't require a resistor, but maybe I'll just put one in to see if that works. My plane is in the paint shop right now, so I can't do anymore experimenting until it's home, but since I've never flown a carbureted airplane that had a carb air temp indication, I can't say that I even miss it. When I get it back home I'll fool with it and get someone at Dynon to give me some advise, but I don't have a lot of confidence it will ever work. I probably need a new probe.
Scott
RV-8 Fastback
