Old 10-30-2005, 08:36 PM
Jamie's Avatar
Jamie Jamie is offline
Default RV in Two Car Garage
Just in case you're building your RV and you wonder if you'll be able to fit it in the garage with wings on....
My garage is 19.5 feet by 21 feet. I have about 4 inches from leading edges and ailerons to the walls/garage door. ;-)
Still got an interference issue with the rear spar...looks like I'll need to trim it down just a bit to get it to no sweep (ok according to Van's incidence FAQ)...but everything else was waaaaay easier than I thought it would be.
Old 10-30-2005, 08:51 PM
txaviator's Avatar
txaviator txaviator is offline
Default Envy.....................
Must be nice in a 'two-stall' garage! I am working in a one hole'r detached shop (hangar)
Gary Robertson
Arlington, TX
RV-12 Built / Sold / Flying
Currently Flying: Cessna Skyhawk 172
Rebuilding a true barn find J-3 Cub
Old 10-31-2005, 08:02 AM
rjsflyer rjsflyer is offline
Must be even nicer to have a wife that will park her car in the driveway, too.
Rick Schwandt
RV-9A Fuse
www.rjsflyer.com
Old 10-31-2005, 09:01 AM
Shoot, I got all excited and then ran out to measure *my* two-car garage.... 19 1/2 X 18.75.
Dang.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 10-31-2005, 09:15 AM
Davepar's Avatar
Davepar Davepar is offline
But how are you going to mount the other wing?
Dave Parsons, Seattle, WA, RV-7A, sold
www.dualrudder.com/rv7 - building blog
RunwayFinder.com - airport info, online charts, live METARs, TFRs, etc.
Old 10-31-2005, 09:36 AM
John Courte John Courte is offline
Default Luxurious.
I'm building an RV-7 in a 1-car and sharing it with laundry machines and a hot water heater. I can do one major piece at a time. However, there's a nice barn-sized slab in the backyard with nothing on it at the moment... The RV isn't going to be the only kit assembled during this project, I guess.
Old 10-31-2005, 10:35 AM
tomwebster's Avatar
tomwebster tomwebster is offline
Same here, building in a one-car garage.
I boxed myself in a corner by not finishing
the tail fairings while I had the tail feathers
on. Now the engine is mounted, I can't
put the horizontal back on and will have to
do the tail fairings at the airport.
Tom Webster
Old 10-31-2005, 04:54 PM
Rosie's Avatar
Rosie Rosie is offline
Location: I live in on the Rosamond Skypark (CA) and am married to Victoria (Tuppergal).
Default 2-car garage
We used only half the 20'x20', two-car garage for our RV-6A until getting to the fuselage. Here's how we did the fuselage-wing flaps/ailerons/push-tubes/wiring etc then reversed the fuselage for the other wing.
We were able to complete the entire plane at our house and did not move to the airport until there was ABSOLUTELY, POSITIVELY, nothing more that could be done at home.
We arrived to the airport on May 13th, then two weeks to assemble, one week to rig, one week for inspection and were signed off by the FAA on June 13th. First flight was 5 days later Rosie
Paul A. "Rosie" Rosales
Rosamond Skypark (L00), CA
RV-6A, 4200+ hours since 7/4/2000
Old 10-31-2005, 07:59 PM
Jamie's Avatar
Dave:
I think you're joking (based on the smiley) but just to clarify since the pictures don't show it very well...both wings are on there.
Old 10-31-2005, 09:25 PM
ericwolf ericwolf is offline
Default When to mount wings?
Thanks Jamie for that post, I've been considering mounting both wings in my 20.5 X 20.5 garage, and I now know that it is possible.
Sorry for the minor thread hijack, but when do the wings really need to be mounted? In other words, could I mount the wings and set the incidence as a last step? If so, should I at least mount one wing at a time to route the wires and rig the ailerons & flaps? I'm trying to avoid the crowded situation that Jamie had, but I suppose that it would only be temporary.
Eric Wolf
RV-8A Flying since May 2009, 300+ hours
Mattituck IOF-360, WW 200RV Prop
N184EW
Past President, EAA838 Racine, WI
