Help with PCU 5000X governor install/setup
Background:
RV-6 0-360A1A hollow crank.
Accessory case changed to accommodate new PCU5000X.
New flex line from Governor to front crankcase port.
Used C/S prop from RV-8 upgrade to RV-200 prop, approx 300TT on prop.
Installation was straight forward, I did have to rotate the lever plate to get it to properly align with the cable and bracket, but just loosened the 6 screws a little and rotated the assembly. The run-up showed prop cycling, but slightly sluggish.
On takeoff, the prop started to over speed, so I pulled prop control back to 2700.
Climbed to 1500 agl leveled off and tried to set prop control but couldn’t.
The prop wouldn’t respond at all, although I watched the engine oil pressure readings and
saw a one to three lbs drop with each prop control cycle. I could over speed the prop with the throttle.
So it appears to work on the ground in a no load situation but somehow doesn’t appear to be able to work in the air with air-loads on the prop.
I know I need to adjust the governor back to a 2700rpm stop but assumed if I controlled the rpm with the prop cable, it would be the same effect as changing the set screw on the
PCU5000X. Am I wrong? Do I need to adjust the set screw to be able to control the prop on flight?
I don’t want to think I got a defective PCU5000X…….could I be the ONLY one???
I do have another C/S prop on another RV-6 in the same hangar and I might swap a KNOWN propeller for a "unknown used" propeller and
that would take the prop out of the problem solving solutions.
I did purchase the PCU 5000X in the latest group buy and will surely be on the phone to
Bob at American Propeller to ask for help on Monday but appreciate any input from any of you fellow RV’ers.
Thanks in advance.
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Reason: changed info after checking part of the problem.
