Check your Prop Manual
It covers what is acceptable in regard to the location of and how many washers. For my prop it is a minimum of one washer next to the locking nut and a maximum of 3 washers total. You will want to check you manual for the specifics of your prop but I would suspect you do not need the washer and the spacer.
Hartzell HC-C2YR-1BFP, Istallation and Removal, 61-00-15, Page 3-6 and 3-7.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
