Old 01-23-2009, 12:47 PM
wrongway john wrongway john is offline
Default 43.3 mpg in a two-seater RV?
I like speed as much as the next guy, but I?ve always enjoyed gas efficiency even more.
I?m sure the present low fuel prices are not going to last long, which is even more reason I would like to concentrate on this.
With gas miser type mileage, who can claim the King?s seat here?
I think everybody on this forum is already familiar with Kent Paser and the amazing speed and efficiency he got out of his Mustang II with the modifications he did.
This could as easily be applied to Van?s RV?s. And actually we already have a leg up on the Mustang crowd simply because we already have the fastback versions, which is something the standard Mustang II?s don?t have.
I think it?ll be worth noting what modifications others have done with their RV?s to increase gas mileage.
Would our RV wing verses the Mustangs laminar flow help, hinder or neither in our quest for great fuel efficiency?
Kent lists in his book that at 2,200 engine rpm, he has a true airspeed of 173 mph, fuel consumption of 4.0 gph, which comes out to 43.3 mpg. How do the best of the fuel efficient RV?s series fare?
wj
Old 01-23-2009, 01:26 PM
RVAddict's Avatar
RVAddict RVAddict is offline
wj
See HERE.
This is in an RV-3. Hard to imagine a two seater doing better...
"Shake the hand that shook the world" - Walter O'Dim
Old 01-23-2009, 01:53 PM
bhassel's Avatar
bhassel bhassel is offline
Default fastback
I know I've seen some 4 & 8 fast backs, but does the shape of canopy on the side-by-side count as a fastback?
Bob
Bob Hassel
NM
Subscription Paid for 2020
Home is where the hanger is...
Old 01-23-2009, 02:51 PM
Originally Posted by RVAddict View Post
See HERE.
Thanks for the link. Gotto love than panel too. Yeah, I'm sure the one seaters will have the advantage here.
I know of a guy that swore his one-seater Mustang was only burning 3.0 gph at 150 mph cruise, and he said he knew this because that is what his monitor showed. He was also trying to sell me a plane, but I still figured he was probably telling it straight. That plane is still for sale, btw, if anybody is interested. He's down to $14,000, and not a bad looking Mustang.
wj
Old 01-23-2009, 02:52 PM
Bob
I suppose the 4?s and 8?s wouldn?t probably qualify as a fastback model since their bubble canopy?s rise up considerably from the back, but dunno. I used the terminology that Kent used, and still would enjoy hearing about their efficiency as well. I was thinking more of 6, 7?s and 9?s as the fastback models for the two-seaters, but maybe others would describe them differently.
I also think the RV-3 would benefit by going to a fast back model as well.
I recently re-read up on Kent?s two-seat Mustang, and took note that when he did his first test flight after his fastback conversion his top speed had increased by 12 mph.
wj
Old 01-23-2009, 03:44 PM
bhassel's Avatar
Default fast back
Boy that's enough speed increase to make anyone take notice.
Yeah, I'd be curious if anyone has fastback'd a side-by-side. I've seen a couple of 8's & 4's (of course the HR).
Bob
Bob Hassel
NM
Old 01-23-2009, 04:03 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default Speed vs. $$$
You will get the best mpg at your best L/D but that's pretty slow for an RV. Around 96 kts/110 mph for a 6 or 7, give or take. You should use about 3.3 gph at that speed for about 33 statute mpg. This is based on the CAFE 6A and is quite close to the actual readings for my 7A.
If you want to go faster you will get good mileage but not as good. Of course, if there is a HW or TW, these calculations will vary, sometimes a lot.
The best trade-off speed is 1.316 times best L/D, also known as Carson's speed. The CAFE 6A will burn about 5.0 gph at 139.5 mph, its Carson's speed. That's about 28 mpg.
These speeds and fuel flows are at standard conditions where TAS and CAS are equal. My understanding is that you can do a lot better at higher altitudes. I typically cruise my 7A at 8.0 gph doing 155 kts KTAS or better at density altitudes between 5,000 and 8,000, but it's just a personal preference.
I suspect a 4 or an 8/8A can do a little better because of the narrower fuselage, but the difference will not be huge.
You may see claims that greatly exceed these numbers, but I'd be wary of accepting them at face value, given the verifiable source of this data.
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Old 01-23-2009, 05:17 PM
zav6a zav6a is offline
Default Kent's Mustang
Is in my hanger. The contrast in wing thickness and chord to an RV is remarkable. That alone probably dictates that we won't get our RV drag down to where his is no matter what we do. Lots of other neat features on Kent's plane too.
____________
Duane Zavadil
RV-6a, IO-320
Old 01-23-2009, 05:37 PM
I appreciate the info about the L/D, carson?s speed and such. It will give me some general guides to go by.
It does help to have much of this verified as possible which is I feel like Kent Paser?s data is accurate, and I don?t mind quoting from him. He documents his work well, has a degreed aeronautical engineer background, and has much of his results also documented in the Oshkosh Pazmany efficiency contests, CAF? races and other events; and has won numerous awards for the modification he has done with his Mustang.
wj
Old 01-23-2009, 05:43 PM
I'm aware of many of those neat features, his "Speed with Economy" is a must read for any plane enthusist, and is a great inspiration to all builders. I figured most around here have already read it.
I've often wondered about that wing, and wondered how much that may have helped him. But I also understand quite a few that go with that laminar flow wing don't get it right, and few realize it's true potential. It's obvious Kent got it right.
wj
