Old 01-21-2009, 09:53 AM
Jeff A's Avatar
Jeff A Jeff A is offline
Default 4-40 Nutplates
Does anyone know where to get K2000 type (one lug) platenuts for 4-40 screws? Does anyone know if they even exist? I've tried to search for K2000-04 and MS21051-L04 part numbers with no results. Any help would be appreciated.
Jeff Atkinson
RV-8 #82594 Flying since May 2012
Barrett XP-360, Catto 3-Blade, Dual G3X Touch, GTN-650, VP-X
Old 01-21-2009, 10:23 AM
noelf noelf is offline
Default Skybolt...
...advertises on this website. Take a look as they do have several flavors of 4-40 nutplates.
Old 01-21-2009, 11:04 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
http://www.gen-aircraft-hardware.com/store.asp
Open "Captive Fasteners" on the left menu. Use the "tech info" to select type, in case you need more detail.
Owner is a RV builder, and frequent poster on this forum.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-21-2009, 05:26 PM
Alschief Alschief is offline
Default 4-40 Nut Plates
Try Cleveland Tools
AL & Brenda Smith
RV12, UL Power N495BA Flying
RV6 N495AB Sold
KEOS Neosho, MO
alsmith@olemac.net
alsmith@ulpower.com
Old 01-21-2009, 06:50 PM
GAHco's Avatar
GAHco GAHco is offline
Default try these!
Try MS21071L04 They are the same except for close quarters.
When you go to this click on Basic Image
http://www.gen-aircraft-hardware.com...ate=MS21071L04
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 01-22-2009, 06:33 PM
GAHco's Avatar
Default Fixed error on web.
I checked the price on these today and Wow, they were wrong.
I took the time to fix them, they are still "not cheap", but they are out of the ridiculous range.
To those of you who were flabbergasted I do apologize.
Get em in the Sky!
Tom Brink Pres.
Old 01-22-2009, 09:00 PM
Jeff A's Avatar
Tom,
Thanks. Those will work perfectly. I'm working on a list of other needed hardware and I'll contact you shortly. Thanks again.
Jeff Atkinson
Old 01-22-2009, 09:43 PM
bweiss's Avatar
bweiss bweiss is offline
Default 4-40 nutplates
Jeff,
Try a company called aircraft hardware They have lots of great hardware and their catalog is a great reference tool
Old 01-23-2009, 08:04 AM
GAHco's Avatar
Thumbs up Happy to help.
Tom,
They do work nicely. They are pretty small so with my Banana fingers I had to be patient with myself when installing them. At least they are not like the mini NAS version, they use 1/16th rivets and those are really a pain, especially in fiberglass. These use 3/32 rivets.
I used these on my rudder caps (top and bottom) to keep the wight down on a dynamic control surface. I will see if I have a pic I can post later.
One other suggestion, if you are going countersunk, use nas514 screws, the nutplates are pretty grippy and these work better due to they are a higher strength alloy and there is less tendency to strip the Phillips drive out on the screw.(also use a new #1 bit)
Best wishes.
Get em in the Sky!
Tom Brink Pres.
