Old 01-20-2009, 07:25 AM
rwshooter rwshooter is offline
Default Wing Question
Started building my RT wing.....I got the rib orientation wrong and before I caught it I drilled the holes for van's conduit at what I thought was the top, forward corner of the main ribs. With the ribs correctly placed, the conduit will be at the bottom forward corner of the ribs.....anyone see a problem with having the LT wing conduit at the top of the ribs and the RT wing at the bottom? Access to bucking the forward rivets in the bottom skins should be fine as there is about an inch between the rivet line and the conduit,
Robb.......7A
Old 01-20-2009, 08:15 AM
TerryWighs TerryWighs is offline
No problem. As long as the placement does not restrict rivet bucking, or cause any problems with control rods...life should be good.
RV-8 builder..."Reindeer Man"
Fairbanks, Alaska
http://www.mykitlog.com/twighs
empennage done
Wings done
Fuselage kit 90% done...
Old 01-20-2009, 09:07 PM
I was hoping for that reply.........thanks Terry
Robb....7A and 2 new ribs ordered..
Old 01-20-2009, 09:32 PM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by rwshooter View Post
...Robb....7A and 2 new ribs ordered..
Ribs don't cost that much, just don't ask me how I know.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-21-2009, 06:49 AM
Michael Burbidge Michael Burbidge is offline
Default Bucking problems
The think the RV-9 instructions say that if you get them wrong it will make access difficult when bucking. I have no experience to confirm or deny this.
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 01-21-2009, 10:42 AM
RyanM RyanM is offline
You want to follow Van's instructions on conduit location. The problem isn't so much bucking rivets when skinning the wings, its when you go to poke a hole in your fuse for the wireing. It will end up in location that isn't ideal.
http://www.vansairforce.com/communit...ocation&page=2
Vans Instructions on wire locations
http://vansaircraft.com/pdf/Wing_Wiring.pdf
Ryan
RV-7 - Wings
http://moener.blogspot.com/
Old 01-21-2009, 02:25 PM
n2prise's Avatar
n2prise n2prise is offline
Default Two conduits in each wing.
I ran two conduits in each wing. One conduit exclusively for the strobe light cable and the other conduit for the 12-volt lights, auto-pilot servo, etc.
http://www.n2prise.org/rv9a015.htm
Jerry K. Thorne
Built in East Ridge, TN.
Now in Palm Bay, Florida
RV-9A - - N2PZ
www.n2prise.org
