Old 01-19-2009, 07:20 PM
TX7A TX7A is offline
Default ACS control cables rubber boots / grommets
I had been looking for the rubber seals that are used on the control cables that Van's supplies (They are made/supplied by Aircraft Spruce). After being on the phone a couple of times with Kim at Spruce, she called to let me know that they have been added to their product line....saying that they were a 'new' parts. Now, I don't know if these things have been available a while or not, but I thought I would post this for those that need to replace theirs. I suspect that replacing cracked seals will help keep the dirt out and add life to the control cables.
Here are the part numbers for the two sizes:
05-02633
05-02634
http://www.aircraftspruce.com/
Sam Evans
RV7-A O-360 C/S
VAF#812
Old 02-03-2013, 12:18 PM
#N72CR #N72CR is offline
Thank you for posting these part #'s. It appears the ACS control cable rubber cracks and fall off after about 2-3 year. I'll bet many RV's are running around without them, and don't even notice that they are missing.
again....thanks for the part #'s
CR
Chris
RV-7A
