Old 01-19-2009, 04:40 PM
RickWoodall's Avatar
RickWoodall RickWoodall is offline
Default trigear nose mount hole in firewall.
Just getting ready to install engine mount. Having trouble wrapping my head around having to drill holes in the firewall for the nose gear leg attach bolt. When we are so worried about the need to make the firewall as safe as we can and sealing up the holes we need with all sorts of special things, this just seems goofy/poor design that we must cut/drill a hole when from first look it seems that if the bolt went in the other way it would work. Anyway of not drilling this hole? Just one of those things were i would rather see if there is a better way or idea as i am not 100% happy with the plans and how that will look etc.
Any suggestions or just drill and move on and get over it?
Rick Woodall C-GSTT "ghost"
9a -TMX io-320, catto three blade, dual dynon hdx with a/p. 900+ hrs in 8 yrs flying.
Flew to Osh 11,12,15,17,19. SNF 2013. West to Cali /Washington/Vancouver/crossed the Rockies north to Red Deer east to Moosonee and over to maritimes. South to Jekyll Isl, cedar key, and Key West etc. 6 trips and 17 islands of the Bahamas. Flown turtles and dogs for Pilots n Paws too. Love our Rv's
Old 01-19-2009, 04:49 PM
AlexPeterson's Avatar
I built my 6A before any of the talk of drilling a hole in the firewall surfaced. I put the bolt in from the bottom, and use one of those all metal, small hex locknuts. The bolt needs to be partially slid through and out of the mount, then start the nut, then tighten. No big deal at all. You might need an extra washer on the bottom to keep the tip of the bolt from contacting the firewall, I don't recall and they are probably all a bit different.
Correction!! I mistyped above. I meant the bolt from the top, nut on bottom. Didn't catch my error until I saw the picture! Sorry.
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 01-19-2009, 05:28 PM
What do you guys do to plug the hole?
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 01-19-2009, 06:01 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Van's included a stainless plug in the kit. I installed and then siliconed it in too.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 01-19-2009, 06:10 PM
Squeak Squeak is offline
I did the same as Alex and installed the bolt from the bottom and metal lock nut on top without any problems.
Squeak
RV7A
Old 01-19-2009, 07:21 PM
Default Thanks
I talked to a builder and will follow his advice. I am NOT drilling the hole. Seems goofy. Several people that drilled the hole as per plans have been able to remove the leg for the service bulletin without needing the hole. Maybe a little awkward but i feel much better then an extra firewall penetration. Thanks all AGAIN.
Old 01-19-2009, 09:03 PM
Besides having to drill the hole in the panel, you may need two people to service the bolt. I understand the heater diffuser panel would also need to be removed. Seems like a no brainer to put it in upside down. I've heard some need to beat a little dent in the firewall, but that is no big deal either.
Alex Peterson
KADC, Wadena, MN
Old 01-19-2009, 09:22 PM
They did? In the finishing kit? Hmmmm... wonder where I put that?
Bob Collins
St. Paul, MN.
Old 01-19-2009, 09:51 PM
mcencula mcencula is offline
Default Firewall forward kit
I believe the plug comes in the FF kit.
Mike Cencula
RV-7A (fuselage)
www.our7a.com
Betcha my pile-o-scrap is bigger than your pile-o-scrap.
Old 01-19-2009, 10:14 PM
rvbuilder2002's Avatar
It's not about being able to assemble it, it's about being able to maintain it.
In a few years after the bolt has possibly rusted in, you may need to remove it for some reason. It is a very simple task if installed as specified...if not ...I guess you can always un bolt and remove the engine mount.
Scott McDaniels
Hubbard, Oregon
