Old 01-18-2009, 08:50 PM
WenEng WenEng is offline
Default Can Someone identify what this extra oil return line outlet is for?
I bought a mid time IO360B1E off a Piper Arrow for my RV6A. Going over it, I noticed this extra oil line welded onto the normal oil return line from left rear cylinder head to the sump. I have no idea what purpose it served. Anyone know what this would have been for? I didn't notice it until after I put on a new Superior cold air sump to point the fuel servo horizontal forward rather than backwards like it was on the Arrow.
Thanks.
""" target="_blank">http://i614.photobucket.com/albums/t...="0" alt="" />
Old 01-18-2009, 08:52 PM
Mel's Avatar
Mel Mel is offline
Can't see your picture, but from your description, my guess would be that it's a drain-back from an air/oil separator.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 01-18-2009, 08:57 PM
Default Sorry... Having trouble posting the picture link.
Old 01-18-2009, 09:00 PM
Mel's Avatar
Mel Mel is offline
Default Yep!
I'll stand by my first guess. A return line from air/oil separator.
Old 01-18-2009, 09:40 PM
Rivethead Rivethead is offline
I do believe Mels right
Old 01-18-2009, 11:51 PM
az_gila's Avatar
az_gila az_gila is offline
Smile Boy....
...I wonder which Piper Arrow STC allowed a hose to hang off a welded joint like that...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-19-2009, 09:48 AM
osxuser's Avatar
osxuser osxuser is offline
Not only is Mel right, as usual, but that IS an approved way to route oil back into a Lyc. If you aren't gonna use it for anything, I personally would fab up a new tube.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 01-19-2009, 10:08 AM
Wicked Stick's Avatar
Wicked Stick Wicked Stick is offline
It might be approved, but it sure looks like a cheesy way to do it.
It is kind of amazing some of the things that get approved and other common sense things do not. Must be the law of averages at work...
Dave "WS" Rogers
RV-8 N173DR
Old 01-19-2009, 02:33 PM
Red face Thanks for the feedback
It is a very substantial weld and for a line returning oil to the sump from an oil/air separator I am comfortable with it and may incorporate it into my oil/air separator when I get that far unless I discover a better way beforehand. It sure is a simple task to create a new oil return tube without this added line. Being one of the newer builders here I really appreciate everyone's interest in helping with advice.
Old 01-19-2009, 07:32 PM
aerhed aerhed is offline
I've seen lotsa Walker returns like that. For Connies they drill a hole in a rocker cover. It works, too bad the separator itself doesn't work. Separators are usually just a cover-up for bad jug walls. On long flights they often just get overwhelmed. A good lyc. should go at least 15 on a quart. Really good ones can go 25hrs/qt.
