Old 01-17-2009, 09:48 AM
Dean Dean is offline
Default Throttle Quadrant Info Wanted
I am looking for a nice 3 lever throttle quadrant for my RV-7A. Infinity Aerospace does not have theirs available yet. What else is out there. I wanted a unit that mounts under the panel (not the push/pull through the panel). I am looking for suggestions and vendor websites. Thanks, Dean
Old 01-17-2009, 09:59 AM
panhandler1956's Avatar
Default ACC
Here's one from Aircraft Spruce. I belive it is a Dayton Murdock unit which is who makes the duluxe RV-8 throttle quadrants for Vans.
Brent Owens
Columbus, OH
RV-8 'Contrary Mary' flying
N784DE S/N #82614
www.fixedwingbuddha.com
Follow me on Facebook
Old 01-17-2009, 11:06 AM
davcor davcor is offline
Cool I have one I don't need
Hi,
I have the 3 lever throttle quadrant shown in the earlier post.
Air Craft Spruce P/N 05-00701 * $210.95 (current list) CMCT3L
Went a different way (engine, prop, etc)
I'll let it go for $185 (shipping included)
Dave Cordner
Dave Cordner
RV7 - N898DC (rsvd)
Fuse, Finish, FWF
Arvada, CO
Old 01-17-2009, 11:58 AM
How is it attached to the panel? Are there special brackets etc...
Old 01-17-2009, 12:47 PM
Cool Throttle quadrant/attachment
How to attach? Well this is experimental right? You decide.
I had planned to use 3/4" angle to build a little frame. I have the affordable panel (XL) which has 3/4" angle at it's base. I cut off the sub panel bottom flange added 3/4" angle to the sub-panel bottom for extra support (decided this after the quadrant was out of the picture). So if I was still going to use the 3 lever, I would run 3/4" angles down both sides and have a nice rigid setup.
Some of the push/pull control setups I've seen and flown in (RV6 & 7's) are a little too loose/flexible for my satisfaction.
I'm sure if you surf around and look at other folks projects, you will see multiple solutions.
Dave
Dave Cordner
RV7 - N898DC (rsvd)
Fuse, Finish, FWF
Arvada, CO
Old 01-17-2009, 01:06 PM
Cool Wow, Infinity Aerospace quadrant early (order) price $1000
I just looked (was curious) at Infinity Aerospace web site. Apparently they are taking early orders. Their center mounted quadrant looks like it requires a console between the seats. Loaded CAD ISO views pdf file to see.
Looks like you probably have much more ambitious requirements/objectives than mine.
The quadrant I have is KISS and not bad looking either. With frame between instrument panel, and the forward sub panel would make a nice ridged setup.
Good luck in your project
Dave Cordner
RV7 - N898DC (rsvd)
Fuse, Finish, FWF
Arvada, CO
Old 01-17-2009, 01:34 PM
N200PF's Avatar
N200PF N200PF is offline
Dean - I just ordered one of these from Andair.
Here is the link to their site: http://www.andair.co.uk/pages/quadrants.shtml
I like this design and the flap switches on the throttle! Also, I believe it will be very smooth because there is no metal on metal contact as with some other throttles that have been mentioned here. (I tried on of those)
Infinity has a good idea but I'm not sure I want ALL that stuff on my throttle. This seems just about right and Andair has a super reputation for producing very high quality products. I'll post an update as soon as I have it.
- Peter
Peter Fruehling
St. Paul, Minnesota - Based at ANE
RV-4 - Sold
RV-7 - Sold
RV-10 - Partners in N829EC
2019 Dues Paid - Have you paid yours?
Old 01-17-2009, 01:40 PM
N200PF's Avatar
I just looked at my own link above and notice that they have taken the price down. I paid $361 U.S. Dollars (£245 British Pounds) for this last week. It seemed VERY reasonable for this piece including the switches.
It's worth a look.
- Peter
Peter Fruehling
RV-4 - Sold
RV-7 - Sold
Old 01-19-2009, 06:34 AM
Dave, sent you pm
Dean
