Old 01-16-2009, 08:46 PM
rwshooter rwshooter is offline
Default sealin the tank issue
I'm about to seal up my first tank....baffle install....when double checking everything out before hand, I noticed a bum rivet at the inspection plate nutplate rivet....I prosealed that area yesterday...so when I drilled out the rivet, I sent shavings inside and out of the inboard rib....inbedded in the proseal...I've tried to brush them out to no avail...help?.....what to do next
Robb.....gonna finish this first wing ....this weekend
Old 01-16-2009, 09:13 PM
scard's Avatar
scard scard is offline
Take a deep breath and get all of the **** out of the tank before sealing it up. (period). Sounds like the rear baffle is still off. You have all the time in the world to work on it. It might be useful to even let some of the new proseal to stiffen more (a few weeks) to extract and reseal where some of the drillings landed.
Scott Card
CMW E-Lift
Old 01-17-2009, 05:52 AM
That's exactly what I'm going to do Scott.......Thanks
Robb
Old 01-17-2009, 05:59 AM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
if you do find that you need to drill around proseal that is not yet set up you can try making a tape nest around the rivet to catch and contain shavings.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 01-18-2009, 09:03 AM
Default ONE MORE QUESTION
I fixed the shaving issue in the proseal and installed the baffle....all went well....Ive seen some people using different screws for attaching the inspection plate, they look good and I'm going with it but most are also using proseal along with the cork gasket to seal up the plate and screws. Is this good if someday you may need access?
Robb
Old 01-18-2009, 09:42 AM
Mel's Avatar
Mel Mel is offline
Default Don't use the cork gasket!
Use proseal only. The cork gasket will soak up and begin to seep after a few years. I've removed many of them.
Use proseal and hex cap screws.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 01-18-2009, 10:05 AM
osxuser's Avatar
osxuser osxuser is offline
They make a version of proseal that is for removable plates, I don't remember the p/n, but it is pink in the tube before it's mixed. Helps greatly if you ever have to remove the inspection plate.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 01-18-2009, 10:45 AM
Got it.....Thanks
Robb
Old 01-18-2009, 11:05 AM
az_gila's Avatar
az_gila az_gila is offline
Smile That would be the....
...same stuff that seals the access plates on the lower surface of my Tiger wings.
It is "low adhesion" FlameMaster CS3330B-2 or Desoto/PRC PR1428B.
This is one unverified source - SealPak Company, Wichita, KS. Phone is 316-942-6211 - A verified source is Fletchair in TX http://www.fletchair.com/
More info here on VAF
http://www.vansairforce.net/articles/tank_sealant.pdf
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-18-2009, 11:18 PM
GAHco's Avatar
GAHco GAHco is offline
Default Thanks Mel
I am not flying yet and I have the Cork Gaskets, I was not aware of their poor longevity.
I will be switching to pro-seal, if not before I fly, then at the first condition inspection one year later, when I have a good look-see at the fledgling's spar.
I had already used the Hex Head Screws NAS1096 or NAS1801's on this cover for ease of installation and removal with the torque controlled screwdriver.
If other readers are not familiar with these, they are a terrific for non slipstream uses, clamps, brackets, covers etc.
To see the tech sheet go to:
http://www.gen-aircraft-hardware.com.../nas1801_2.pdf
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
