Old 01-16-2009, 10:32 AM
Michael Burbidge Michael Burbidge is offline
Default What tools needed for tank plumbing
What new tools will I need to do the fuel tank plumbing? I have the standard kit from Cleavland. I'm using the standard Van's sender.
Michael-
Michael Burbidge
Sammamish, WA
RV-14A Empennage
RV-9A Flying?340 hours!
Last Donation: December 2019
Old 01-16-2009, 12:02 PM
RyanM RyanM is offline
I think the only thing you'll need is a flaring tool. Parker Rolo flare works great.
Ryan
RV-7 - Wings
http://moener.blogspot.com/
Old 01-16-2009, 12:04 PM
schristo@mac.com's Avatar
schristo@mac.com schristo@mac.com is offline
pipe cutter, flaring tool, crows feet, torque wrench... for the tank you can get by without a bender, but you will need one later.
Stephen
RV7 powered by a lycoming thunderbolt IO-390
turning a whirlwind HRT prop
with more hours flying than building... 2,430 on the hobbs!
ORCA Flight
Race 771
margarita!
Old 01-16-2009, 12:14 PM
N941WR's Avatar
N941WR N941WR is offline
You will need four tools to do your fuel and brake lines.
1) Tubing cutter
2) Flairing tool
3) Spring benders
4) Tubing bender
5) Torque Seal to mark the fittings after you torque them.
Just remember, you will need a 37 degree flairing tool, the rest you can pick up locally. There was a thread a few days back on the best flairing tool to use. You can find it in a search. I used the flairing tool in the picture above, FWIW.
This assumes you have crows feet and a torque wrench.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-16-2009, 01:31 PM
Default Crows feet?
What is a crows feet?
Michael Burbidge
Sammamish, WA
RV-14A Empennage
Old 01-16-2009, 01:40 PM
Default crows feet
Stephen
ORCA Flight
Race 771
margarita!
