control cable sheath slipping
I've hooked-up my cabin heat control cable as shown in the plans. The plans show safety-wiring the sheath around the adel clamp on the firewall to prevent slipping. I can't get a safety wire around the sheath tight enough so that it does not slip. I mean the sheath slips back and forth through the adel clamp, and through the loop in the safety wire, as i push and pull the control knob.
Any other ideas on how to secure the sheath of the cabin heat control cable so it won't slip? I thought of proseal, but suspect that over time it would work loose and slip again.
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
