Old 01-15-2009, 03:39 PM
prkaye prkaye is offline
Default SCAT tubing on cabin side?
I've been going through all the drawings, and haven't found any that show how to connect-up the cabin vents. Questions:
1) I presume that some SCAT tubing plugs into the vents... does this then somehow interface directly to the NACA vents?
2) What about the cabin heat? Does the cabin heat box somehow connect to the vents so that warm air can be selected to come out of the vents, or does cabin heat only come directly through the hole in the firewall? I can't see how you would attach SCAT tubing here, with the arm for the cabin-heat control cable in the way.
3) Does anybody have any good photos showing this stuff on the cabin side?
Thanks!
Phil
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 01-15-2009, 03:46 PM
Default FOUND THEM!
LOL just after I posted this I wandered down to the basement and found a bag full of black tubing and stuff that had come with my finish kit a while back. Opened it up and there's a supplemental drawing and instructions page for the vents!
One question still remains... what about cabin heat? Is there no way for it to go to the vents? Looks like it just pours in through that hole in the firewall where the cabin heat box is mounted?
Phil
RV9A (SB)
Ottawa, Canada
Old 01-15-2009, 03:49 PM
mburch's Avatar
mburch mburch is offline
The center tunnel cover has louvers in it... the hot air comes out of there.
mcb
Matt Burch
RV-7 (last 90%)
http://www.rv7blog.com
VAF #836
Any opinions expressed in this message are my own and not those of my employer.
Old 01-15-2009, 06:11 PM
N941WR's Avatar
N941WR N941WR is offline
Phil,
When you put the SCAT tubing on the NACA vents, clamp some screen material in there to keep the bugs out. Here's a picture:
I had to use a different type of tubing because of the vents that were given to me. However, my tubing was special made for Van's RV's. Here's a picture to explain:
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
