Go Back   VAF Forums > RV Firewall Forward Section > Propellers
Old 01-15-2009, 11:10 AM
JHines JHines is offline
Default Does CS prop help in IMC?
I've got a decent amount of hours in IMC behind a FP propeller. At times it results in a lot of throttle jockeying in heavy updrafts and downdrafts.
I have only flown with a CS prop in VMC on basically calm days. Those of you who have flown behind a CS prop in IMC, do you find it makes engine management easier? Can you just "set and forget" the RPM?
Jonathan Hines
Charlotte, NC
Old 01-15-2009, 11:16 AM
Kahuna's Avatar
Kahuna Kahuna is offline
I suppose. But its not really a set and forget, in fact its one more thing to deal with. I could make the argument that a c/s prop under a high workload enviornment like IMC adds to the list of things to deal with. I certianly would not have listed "management in IMC" in the top ten reasons to own a C/S prop. Nor would it be in the top 50 items on my mind for things to deal with IMC. I dont consider it a factor one way or the other.
Kahuna
6A, S8 ,
Facebook, Track Me
Gold Hill, NC25
Old 01-15-2009, 11:25 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I agree with Mike - management of RPM wouldn't be anywhere near the top of my list of things to manage in IMC. In fact, after initial climb, I usually set the RPM I like, and don't touch it again until short final.
But then, flying a fixed pitch prop in IMC, I set up cruise power and then don't touch the throttle either - I fly pitch (or let the autopilot do it). Never really thought about playing with the throttle, unless I am managing a descent.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-15-2009, 12:30 PM
<SNIP>
Paul
Hi Paul,
I know in extreme situations one should just fly attitude, keep under Va and tell ATC "unable" on the assigned altitude.
I am thinking more of situations such as maintaining altitude +/- 100 feet while transiting 300 to 500 FPM updrafts/downdrafts.
Maybe I'm using some poor piloting techinques, but I've found that in a Skyhawk or similar in such conditions, I would need to pull the throttle to avoid an overspeed or firewall it to maintain altitude.
this is what I do in normal conditions.
Jonathan Hines
Charlotte, NC
Old 01-15-2009, 12:59 PM
captainron's Avatar
captainron captainron is offline
I would have to disagree with the folks who say it's a hindrance. Having the prop governor control your RPM to prevent overspeeding while fighting up/downdrafts doesn't seem like it would be a problem to me. It's almost like saying that managing an autopilot in IMC is just another thing to increase your workload. Simply not the case! Another possible side benefit of C/S is the ability to shed some prop ice by manipulating the blade pitch.
Ron Leach
RV-7 N713CM reserved VAF # 603
Cincinnati
__________________________________________
"Wish I didn't know now what I didn't know then".
.....Bob Seger
Old 01-15-2009, 01:05 PM
Kahuna's Avatar
Good points Ron. I had not considered the blue lever de-ice function before. Thats a good one.
I personally have zero fixed pitch RV IMC time for any comparison.
Kahuna
6A, S8 ,
Facebook, Track Me
Gold Hill, NC25
Old 01-15-2009, 05:35 PM
Kevin Horton's Avatar
Another plus for the CS prop in IMC is that if you screw up and end up in icing conditions, you will have better climb performance to get out of the stuff.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 01-15-2009, 05:42 PM
dpansier's Avatar
dpansier dpansier is offline
Another advantage for the CS the ability to keep your speed up on the approach and still be in a good position to slow down and land. This worked well for me when on the ILS with jet traffic in trail.
Don Pansier
Green Bay, WI (GRB)
RV-7 N450DP
W9LYX
Antennas for Experimental Aircraft
www.deltapopaviation.com
Old 02-13-2009, 10:00 PM
osxuser's Avatar
osxuser osxuser is offline
CS prop is less workload in the air... no matter, VFR or IFR.
RV4 wing in Jig @ KPOC
RV7 emp built
Old 02-13-2009, 10:10 PM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
I agree with that but there are times when you have to pull and push that throttle (or prop control) with either prop type. Today there was pretty strong mountain wave activity along my route and I had to pull the throttle back on my fixed pitch equipped airplane to keep the indicated airspeed to something reasonable in the ups. I would have had to do just the same with a constant speed.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
