Old 01-14-2009, 07:58 PM
Phil's Avatar
Phil Phil is offline
Default Alodine under Superfil???
For those of you who have long term experience with Superfil, is it acceptable to alodine the scuffed/prep'd surface underneath?
I'm looking to fill a few dents while waiting on the QB fuse to arrive....
Phil
Old 01-14-2009, 08:58 PM
newtech's Avatar
newtech newtech is offline
I alodine'd all my aluminum panels before any bodywork. Used Super-Fil on the aluminum and fiberglass before primer. Won't be flying until this spring but I feel the alodine gives a little extra tooth for the finishing materials to grip to. I stay away from polyester based fillers directly on epoxy parts as the bond of polyester to epoxy isn't very good.
______________________
Steve Eberhart, W9JUQ
3EV - Evansville, IN
Where is Steve and the Sky Terrier?
RV-7A Slider, O-360 A1A, Catto 3 blade, 2 screen Garmin G3X Classic, GTN 650, Bionics APRS. FLYING since June 24, 2009
EAA Chapter 21
Old 01-15-2009, 05:31 AM
Phil's Avatar
Originally Posted by newtech View Post
Used Super-Fil on the aluminum and fiberglass before primer................. I stay away from polyester based fillers directly on epoxy parts as the bond of polyester to epoxy isn't very good.
This suggest the Van's parts are polyester and not epoxy??? I haven't gotten that far in the kit yet.
Old 01-15-2009, 08:12 AM
newtech's Avatar
If there is a white gel-coat then the parts are polyester but if they are the green/pink color they are epoxy.
I have used polyester based fillers (bondo) on epoxy glass parts in the past and have been able to pop the polyester filler off just by flexing the part.
EAA Chapter 21
Old 01-15-2009, 09:39 AM
Phil's Avatar
Great to know.... Thanks!
