Old 01-12-2009, 08:46 PM
szicree szicree is offline
Default Advice on Fuselage Transport
Anybody ever use a rental truck to move a fuse on gear with engine? If so, how'd you get it into the truck? Ramps? Manpower? Any advice is much appreciated.
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 01-12-2009, 10:39 PM
hgerhardt's Avatar
hgerhardt hgerhardt is offline
Put my fus on a car trailer facing backwards. The landing gear was too wide to roll between the fenders of the trailer, so rather than devise a set of ramps to go over the fenders, we just put the tail first. I had all control surfaces installed and used mylar tape to keep them from flopping around. The cowling, engine, prop and canopy were all installed, too. I drywall screwed a pair of 2x4's crosswise into the wood trailer bed to lock the main gear wheels. I had the wings leading edge down in a cradle in the bed of my pickup. I drove on the freeway for about 50 miles like that and had zero problems. Was quite the spectacle!
Heinrich Gerhardt
RV-6, flying, 200.0 hours
Old 01-13-2009, 04:22 AM
decathlon737's Avatar
decathlon737 decathlon737 is offline
Default For moving a short distance
Try this if you aren't moving too far away.
Bill Woods
RV8 sold 180 hrs. of pure joy
(Nov 2018) Bought 7A Tip up
project, converting to tailwheel
slider (just because)
Thunderbolt YIO390
Hartzell BA
Steinair Panel (WOW)
Old 01-14-2009, 12:46 AM
OneCharlieKilo's Avatar
OneCharlieKilo OneCharlieKilo is offline
Default Yes, done it twice with enclosed rental truck
I've used U-Haul truck twice with good success. For pictures of ramp setup, see post at:
http://www.vansairforce.com/communit...952#post236952
Or pictures on web site at (short move to airport):
http://rv6aproject.ckhand.com/finish...AirportPg1.htm
Or (longer move WA to CA):
http://rv6aproject.ckhand.com/Moving...-to-CAmove.htm
Chris
RV-6A, N731CK, 300+ hrs
Poulsbo, WA
