Old 01-11-2009, 05:58 PM
pat pat is offline
Location: Midland, Michigan 3BS Hanger 4B and sometimes at home
Default removing spraylat
whats the easiest way to remove spraylat from a canopy?
Patrick Howe
Citabria 7KCAB - sold
RV8A FB - flying
Old 01-11-2009, 07:11 PM
rwhittier rwhittier is offline
Default Peel it
Get your finger nail under it and peel it off. I hear if its on too long it doesn't do that too well, but its always worked for me. Good luck.
Roger Whittier
RV7A Quick Build, Tip Up
N1MY Reserved - Canopy finished - Wings mated, Engine hung, electrical 95%
Old 01-14-2009, 02:35 PM
flyboy1963's Avatar
....spraylat is part water, so the older it is the drier it is.
In the sign business, we'd often mask an acrylic face, then not use it right away.....bad news. Often rolling on a thick topcoat of more spraylat would soften the first layer, and give a more substantial layer to pull on when peeling. If you dont' have more spraylat, try covering an area with masking tape, than may keep it from coming off in tiny bits.
soaking teh whole thing in water for a week might help, but it's almost impossible to peel when gooey.
any mechanical means will undoubtedly scratch the acrylic.
hope this helps a bit.....best of luck!
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
Old 01-14-2009, 09:00 PM
rv6rick's Avatar
rv6rick rv6rick is offline
JOAT-MON & Moderator
Default It comes off with a little effort
I once had an RV4 canopy that someone coated with Spraylat some 12-15yrs before I got hold of it. Some areas were thick and some thin. Most of it was VERY hard. I tried all kind of stuff to remove the coating but it wouldn't budge. I thought I was going to have to trash the canopy.
Drum roll please.......then I broke out the 3M Adhesive remover. I got the 1 qt. size can from my local automotive paint dealer.....the red and white can.
Using a soft towel I was able to soak a 3" x 3" section of the Spraylat. It gradually got softer and softer to the point it would 'roll up' with the towel and/or your fingers. I worked on the canopy for about 2 or 3 hours per night over the course of about a week doing a section at a time. When I finished the canopy plexi was clean as a whistle.
No Charge for this one....unless you want to buy me a hot dog at Sun n' Fun !
Good Luck.....and let us know how you made out!
Rick Gray in Ohio - Builder Assist Center - 50+ Awards & counting
BRONZE / SILVER & GOLD LINDY AWARD WINNING RV's & Rockets
EAA Oshkosh Homebuilt Judge/Tech Counselor/Flight Advisor / F.A.S.T. Formation Flight Lead
Kitfox/RV4/6/7/8/9/10/12/14?s
6 RV10's
2 Time Sun n Fun Grand Champion
F1 Rocket #1 Oshkosh Gold Lindy Grand Champion!
F1 Rocket #2 :-)
Fastback RV8 Slider
RV14 #2 in progress
53 RV's & Rockets & counting
Whirlwind Prop Dealer
Love my Pitts S-1S
