Old 01-11-2009, 01:38 PM
bkilby's Avatar
bkilby bkilby is offline
Default Big green cable elevator trim question
Does the big green cable make the elevator 'stiffer' in movement for you folks with the manual trim? The elevator movement on my 6A is a little too stiff for my tastes (haven't flown it yet, talking about just movement on the ground), and the only thing we can think of that is causing it is the big green trim cable. When you move the elevators up and down, you can see the cable being moved a little back in the tail, which I think may be causing the stiff movement. The 9A I fly has electric trim and the elevator movement on it is smooth as glass - no stiffness.. Just wondering if it;s the trim cable that could be the culprit?
Old 01-11-2009, 01:54 PM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default Probably not
No way to know - never flew it any other way - but it's quite free and very pitch sensitive compared to even a C-150.
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Old 01-11-2009, 02:03 PM
bkilby's Avatar
Found another post with the same issue on a 9A.. I have pm'd him to see if he resolved it or had any adverse effects in flight..
http://www.vansairforce.com/communit...manual+trim%22
Old 01-11-2009, 02:14 PM
rvbuilder2002's Avatar
The cable does cause some spring resistance from wanting to return to being straight but from just a verbal description I can't say that that is what you are feeling. Their are a bunch of different causes of control friction in the elevator system on an RV so it could be any one of them or a combination of more than one. Pulling the cable fwd out of the elevator and then rechecking would the first place to start looking for it.
BTW I actually prefer the manual trim (I have flown a lot of hours in both) and switching between RV's with manual and those with electric trim I don't notice a difference in the elevator feel in flight.
Scott McDaniels
Hubbard, Oregon
Old 01-12-2009, 10:35 AM
664781 664781 is offline
Default Stiff Control
Mine was stiff after I put the wings on. I found that the brackets for the control column at the wing spar were binding and needed to be shimmed. Just a little difference between the actual wing spar and the false spar I used to mount up the control column caused the problem. I think I had to swap a thick washer for a thin one to fix the problem. This made a huge difference with the Elevator feel on the ground.
Kurt Lohmueller A&P, DAR
Powder Springs, Ga
RV6A "Kurt's Toy" - Flying
RV12 - Flying - Sold
Old 01-12-2009, 11:02 AM
bkilby's Avatar
Thanks.. I'll have to check that.. but man... I don't want to have to take any of those spar bolts out!
Old 01-12-2009, 05:45 PM
billnaz's Avatar
billnaz billnaz is offline
Default check the whole system
My manual trimmed elev. is as smooth as silk. check the whole system for the culpret.
Bill Grischo, Gilbert AZ
N911WG RV-6A DVT
Flying, thinking about polishing
Old 01-12-2009, 06:32 PM
174Bob&Nancy 174Bob&Nancy is offline
I would check the bearing clearance between the left and right elevators I have a friend with a 9 and his elevator was stiff after he bolted the two halves of the elevator together at the center bearing above the control horns this put tension on the outer bearing and create lots of drag,hope this description helps,Bob.
Old 01-13-2009, 09:56 AM
Default I don't want to have to take any of those spar bolts out!
I did not pull the spar bolts, just the hinge/bearing bolt and removed a washer that freed up everything.
Good luck.
Powder Springs, Ga
