01-10-2009, 06:19 PM
Map Box Door Hinge -- Better on the side or bottom
Hi All,
I am installing an AeroTronics fiberglass map box and am having a hard time deciding on whether it is better to put the door hinge on the side or on the bottom. I can see the side having a slight disadvantage as it could swing around while open in flight (although I could squeeze the hinge eyelets to cause some friction). However, putting the hinge on the bottom means the door can just plop down when opened. Just looking for opinions on people that have it either way.
Thanks a bunch.
01-10-2009, 07:28 PM
bottom for me
Mike, I put my hinge on the bottom. Its a rather heavy item used for cabinets but works well. It has good spring tension to hold closed, and it only swings 90 degrees so it is horizontal when open. This way it does not flop around and hit the instrument panel or switches etc. I'll take a picture next time I at the hangar.
Bevan
RV7A wiring
01-10-2009, 07:35 PM
Hey Bevan-
Thanks for the reply. Is that hinge something you picked up at a Home Depot or equivalent?
01-10-2009, 08:09 PM
bottom for me
Bevan
RV7A wiring
01-10-2009, 08:10 PM
Yes
Rona. Canadian equivalent to home depot.
Again, A lttle heavy for the what it does but I can change it in the future if I have to put the plane on a diet.
Bevan
01-14-2009, 02:42 PM
map door hinge
....sorry guys, just have to pipe up here...I have only 14 hours, and already HATE the glove box. Everything you want finds it's way to the back end, and you can't access anything in flight....okay, you shouldn't do that, but let's be real!
eg. I find on my walk-around that I want my flashlight, well, it's impossible to reach in from the passenger leading edge side and grope around to find what you want.
I'd recommend trying to make a 'drawer' that slides out, giving access to everything right to the back!...with a little lip of course to keep it from ending up in the passenger's lap! :-)
Perry Y.
RV-9a - SOLD!....
Lake Country, BC
01-15-2009, 05:35 AM
I put mine on the bottom. I attached a piece of velcro to it and that's where I put my portable music player. I ran the music input wires into the back of the mapbox so they were out of the way when not in use.
Randy Pflanzer
Greenwood, IN
www.pflanzer-aviation.com
Paid through 2043!
Lund fishing Boat, 2017, GONE FISHING
RV-12 - Completed 2014, Sold
427 Shelby Cobra - Completed 2012, Sold
F1 EVO - partially completed, Sold
F1 Rocket - Completed 2005, Sold
RV-7A - Partially completed, Sold
RV-6 - Completed 2000, Sold
Long-EZ - Completed 1987, Sold
