Old 01-10-2009, 12:02 PM
jweaver jweaver is offline
Default Getting started Help / Questions - New to Experimental Aircraft
Good Afternoon,
This is my first RV post, and if I go through with the build (I want too) im sure it will not be the last. Im a 100 hour pilot tired of renting already. I cannot get the plane for the entire weekend for cross country flights and I also have been flying aerobatics (with instructor) in training for IAC basic and sportsman. Wife says I can only own one plane, so I do not want to by a spam can for cross country that cannot do aerobatics, or buy an aerobatic plane that does not go cross country.
I have been looking to sell my 600hp turbo car to start the build. I have experience in building engines as a hobby.
My questions are on vendors and costs vs. the vans site calculator cost.
I am willing to buy an older engine thats out of service time and rebuild.. if it will save money, buy refurbished props or used avionics that are tested.
My questions are around how much I could save over the vans calculator if I build with refurbished (factory or reputable shop) parts? I am also really trying to find a list/websites of places that sell props refurbished vs. new or high mile engines that are good canidates for rebuilds
I am looking at doing an RV8, with an inverted oil and fuel system, open to 160 or 180 hp lycoming, and an aerobatic prop.
Any help on vendors or reputable shops that sell parts at a lower cost than the vans calculators assumed new prices would help me move forward with the decision.
Thank you
Jason W
Old 01-10-2009, 12:45 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF!!!!
Jason, welcome aboard.
Sounds like you have a good start on your decision process, and comming here is another good choice
You mentioned you are married, is she open to flying?? If so, you need to get her input on side by side, or tandem.
The 7, and the 8 are pretty close in performance, main difference is seating.
Many prior threads about this, maybe a good time to get used to the search function here.
FFIW, my wife was not interested in a tandem, that is until I got her a ride in a buddies 8.
That grin lasted for close to a week.
Good Luck,
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-10-2009, 12:55 PM
drill_and_buck's Avatar
drill_and_buck drill_and_buck is offline
Default It would be tough to beat
Hi Jason:
Welcome to wonderful world of VAF and RV building.
I think that Vans estimates are very conservative and would be tough to beat. Its not that you can't beat them but you may be often challenged with scope creep.
Below are Van's estimates...
Price Breakdown Low High
RV-8 Standard kit $20530 $20530
Used mid-time Lycoming $12000 $18000
Hartzell constant-speed prop $6590 $6835
Prop governor and cabling $1350 $1350
Firewall forward accessories $3400 $4800
Analog flight instruments $700 $1000
VFR cross country instruments $1100 $1100
Nav and landing lights / strobes $890 $890
Basic avionics $1000 $2600
Basic electrical system $400 $1000
Cushions / harnesses $900 $900
No paint $0 $0
Mid-US standard kit shipping / crating $850 $1000
Total Kit Low=> $49,710 High =>$60,005
Vans estimates include purchasing a mid time engine and it does not include the cost of a rebuild. CS prop costs are for a new prop. Engine/prop high end estimate is $24,835. If you are planning on an 180 HP/Inverted fuel & oil/Aerobatic prop you *might* be able to save a few k by hunting for some bargains. Ideally an engine/prop combo off an existing RV.
You mentioned that you are currently flying the IAC basic and sportsman sequences. The RV-8 is an aerobatic aircraft however, it is not well suited for IAC competition. It is much too slippery and it builds up speed quickly. If you are planning to use the -8 to compete in IAC events you might want to consider another mount.
Where to look for bargains? VAF, ebay, barnstormers, and the local FBOs would be good start.
Caveat emptor.
Mike Draper
RV-8 TMX0360 CS
N468RV
Finishing
Old 01-10-2009, 01:02 PM
Sam Buchanan's Avatar
been here awhile
Thank you
Jason W
Welcome, Jason.
You are considering a fascinating and challenging journey! Building a plane will make your other projects pale in comparison in complexity and satisfaction. I certainly understand your interest in poking through budget options, I have certainly spent a lot of time there myself.
However..........(you knew this was coming...) I suggest you go ahead and use the figures on the Vans cost calculator for budget planning. This airplane, regardless of your efforts to cut costs, is going to cost more than you now expect. I promise. The Vans calculator is pretty good at allowing for the inevitable budget creep that occurs in every RV project (hey, they base this calculator on the history of 6000 projects) and I suspect your finished cost will be very close to the estimation.
Most likely, by the time you are ready to purchase engine and avionics, the mission profile for your plane will have changed (you will have more pilot experience and RV knowledge) along with your willingness to throw money at something you will then be determined to finish with little compromises. Believe me......I've been in the RV game for twelve years and have seen this little drama play out many, many times.
The vendors that you will want to deal with are pretty much playing on a level field which is dictated by the size of the RV community. If you find someone dealing significantly under market price, watch out.
If I could make one suggestion on your proposed project, it would be to ditch the inverted oil system. It is unnecessarily complex, heavy and costly, and RV's are capable of doing all the aerobatics the plane is happy with without the inverted system.
Get familiar with the search engine in this forum, do your homework, and look forward to flying your own, custom-built aircraft.
Sam Buchanan
RV-6
Fokker D.VII replica
Old 01-10-2009, 07:34 PM
Thank you for the feedback so far! Very helpful! I did try searching for "refurbished","used" parts "vendors" and "Shops" before I made the post...as I am very familiar from my use of car internet sites about search etiquette before posting. My search terms just did not seem to find what I was looking for on the site.
I will run with Vans estimates and just try to save where I can to offest unexpected cost.
Dont know about giving up the inverted oil system. I love slow rolls and inverted flight and pinning the nose on the 45 downline of the cuban 8. I actually dont mind negative gs that much... which must make me an odd ball im sure...but I will search on this more.
Thanks again and hope to get a lot more advise on this post and many more
Jason
Old 01-10-2009, 08:03 PM
N941WR's Avatar
N941WR N941WR is offline
Jason,
Welcome to the VAF forum. You will find many of us on here are former auto racers (Just sold my car before Christmas. )
As you build there are two things to keep in mind. 1. How can I keep it as light as possible. Just like the car thing, heavy weight is a performance killer. and 2. What options are required for my mission.
There are a lot of very nice RV's out there that have a ton of options and others that don't even have position lights. Again, it comes down to YOUR mission.
That doesn't mean you will not have room for "improvements", quite the contrary. One perfect example and budget buster is the Andair fuel valve. It is a few hundred dollars when compared to the boiler valve Van's includes with the kit. You will have to make the choice to use it or the stock valve. Same goes for the engine, do you want to add electronic ignition or not. You get the idea.
As you post and read this forum, you will find there is a LOT of advice on how to do things, in many cases, there are multiple acceptable ways to do the same thing.
If you haven't do so, check out Dan C's web site, http://www.rvproject.com. It will give you a good idea of what you are in for. Just keep in mind, some things on that site (or any site, mine included, for that matter) are not correct and may lead you astray.
A number of people on this board have created web sites, check them out, as you get into this. There is a LOT of good advice on all those web sites.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-10-2009, 08:38 PM
videobobk's Avatar
videobobk videobobk is offline
Welcome!
The only advice I would add to the above is sort of obvious, but you have to be ready to take advantage of bargains. The day I saved over $100 on new seat belts was no big deal, but the time we saved about $10,000 on an engine and FWF from a storm damaged 6A took some Big Bucks. If I hadn't been ready and had the money set aside, someone else would be flying that engine now. There IS money to be saved, but believe me (and everyone else here,) it will just be spent on something else. And it IS worth it!
Do check out both the 7 and 8. And having a wife that sanctions all this is priceless! Keep her in the loop.
Bob Kelly
Bob Kelly, Scipio, Indiana
Tech Counselor
Founder, Eagle's Nest Projects
President, AviationNation, Inc
RV-9A N908BL, Flying
Old 01-11-2009, 05:30 AM
pierre smith's Avatar
Default Good advice from Bob........
.....and we did basically the same thing......a line of credit from my local bank so I could write checks to $15,000. You never know when a bargain shows up......and also...the early bird catches the worm. Check here and Barnstormers early every morning for a jump on a bargain.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 01-11-2009, 07:39 AM
panhandler1956's Avatar
Default Welcome aboard!
Jason,
Glad to see another -8 buider joining the fray - hopefully!
I agree with the good advice thus far. One other point I would add is time. Make sure that your estimates of how long the project will take are not too lean, like budget creep you will certainly take more time than you plan for out of the gate. Modifications are a huge time killer, so you have to do some soul-searching to make sure there is value added.
Most important point - do something on your airplane every day if possible, even if it's only :30 minutes. Keeping engaged will keep you from wasting valuable time and keep the project fresh and IMHO makes it much more fun.
Good luck and hopefully I can park my to-be-finished RV8 next to yours at OSH some day!
Brent Owens
Columbus, OH
RV-8 'Contrary Mary' flying
N784DE S/N #82614
www.fixedwingbuddha.com
Follow me on Facebook
Old 01-11-2009, 07:16 PM
Im estimating if I move forward with the project that it will take me about 3.5 -4.5 years to complete based on 10 hours a week for 50 weeks per year and im betting that would be conservative if not for budget constraints. Im a little OCD (obsessive compulsive) and when I build my cars from the ground up I pretty much live in the garage 24-7 and have a single track mind. My spouse is aware of the behavior after a decade, but it helps that the garage is 75 feet away from the living room.
I am off to my first EAA meeting Tuesday and working on making arrangements I hope to fly in some of the local RVs to decide. Im pretty sure im dead set on tandum in the -8 after flying tandum in great lakes bi planes. I would install throttle controls in the rear, rudder pedals, stick and a few basic instruments so my wife could land in emergency or enjoy flying. She is not a pilot, but does love cross country trips and take the controls(including tv remove ).
Since I already started the thread, two questions:
Is the lycoming 320 cheaper to build and more abundant in parts supply or is the 360 more available...and if I purchase an inverted oil system do I need to still find an aerobatic engine like and AEIO360 or will a regular lycoming with inverted oil survive just fine at the sportsman level?
