Old 01-09-2009, 05:46 PM
avee8tor13 avee8tor13 is offline
Default how did you stamp your dataplate or sent out?
All,
Did any one send out their data plates for stamping or did you do it yourself? If you did yourself, what stamp did you use.
Old 01-09-2009, 06:01 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I just had it engraved at the local trophy shop - simple, and nicely done.
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 01-09-2009, 06:04 PM
n5lp's Avatar
n5lp n5lp is offline
fugio ergo sum
Default Trophy Shop - Bad
I took mine to the local trophy shop and it was incredibly bad when I got it back. Of course I live in a small town and am used to less than good results sometimes.
I used a Dremel Tool to make another one. It is terrible and about 200% better than the professionally done one.
Larry Pardue
Carlsbad, NM
RV-6 N441LP Flying
Old 01-09-2009, 07:51 PM
bhester's Avatar
bhester bhester is offline
Trophy shop for me, worked out great! Cheap too!
Try a different one.
I scanned the plate and put the lettering on it in the computer so I could show them exactly how I wanted it.
Bobby Hester - Builder/Pilot/A&P
Surfing the web from Hopkinsville, KY
N857BH RV7A XP-O360 - Garmin G3X ADS-B IN/OUT 2020 Compliant
Web site: http://www.newtech.com/bobbyhester/RVSite.htm
Dec. 2019 VAF donator - alot better than any magazine subscription
Old 01-09-2009, 07:52 PM
Ted RV8 Ted RV8 is offline
Default Engraving
I first used a trophy and engraving shop and the print looked great. The only problem was it was only about a half thousands deep and it couldn't be seen very well. Cost way to much money also. They complaned about it being Stainless and to tough to go deeper. Most of them engrave on soft materials. I ended up replacing it when it couldn't be read by the inspector easily.
Go to a local CNC machine shop and they can ball end mill it with their CNC mill to any depth you want. I think you want to be .004 to.005 deep minimum for it to be easily seen. If your lucky you'll get a guy who is into airplanes and it can be inexpensive and, or negotiable, ie ride in plane or beer.
Ted
Old 01-09-2009, 09:33 PM
chrispratt's Avatar
chrispratt chrispratt is offline
Super Moderator
Originally Posted by Ted RV8 View Post
I first used a trophy and engraving shop ... They complaned about it being Stainless and to tough to go deeper. Most of them engrave on soft materials...
Ted
Good point, Ted. Make sure the trophy shop knows it's stainless and ask if they can handle it. If they have the right tools it will look fine. I had mine done that way. Took only a couple of days. Of course I live in a big town, but even in Dallas there is only one trophy shop I know of that has the right tools. (It's Holsapple & Sons for those of you who are local.)
Chris
Chris Pratt (2020 VAF DUES PAID)
RV-8 Flying, 850+hours
N898DK
Lycoming O-360-A1A, Hartzell CS
52F (Northwest Regional, Aero Valley, Whatever, TX)
Old 01-09-2009, 09:44 PM
rocketbob's Avatar
Go to Harbor frieght and spend $5.99 on a stamp set and stamp them out yourself.
Next time you happen to see a brand-new A36 Bonanza, note where the dataplate is... its on the bottom of the tailcone, underneath the fuselage. There's nothing in ?45.13 that says it has to be on the side of the airplane.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 01-09-2009, 10:08 PM
Rick_A's Avatar
Rick_A Rick_A is offline
I had mine done by engravers.net and I also got my N numbers from them. Great work at a fair price.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 01-09-2009, 11:48 PM
Default Harbor Freight Stamp Set
I bought the steel stamp set from Harbor Freight and did it myself. It worked fine.
Bob Axsom
Old 01-09-2009, 11:52 PM
dmaib's Avatar
dmaib dmaib is offline
Ditto on the HF stamp set. Worked great.
David Maib
RV-10 N380DM
New Smyrna Beach, FL
VAF Paid 1/21/2020
"In '69 I was 21, and I called the road my own"
Jackson Browne
