Old 01-09-2009, 01:58 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Info request
Can someone who is building a 7, 8, or 9, look up the part numbers for the pieces used to mount the electric elevator trim??
I only need the metal parts------cover plate, nut plate ring, and servo mounting angles.
I figure that these can be adapted for in the rudder of a RV 10 pretty easily, but as the 10 uses a cable driven (remote mounted servo) elevator trim, I do not have the part numbers on my plans.
I already have the servo, just need the metal pieces.
Better still, if anyone out there has extras of the above, I would like to buy them.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 01-09-2009, 02:22 PM
flion's Avatar
flion flion is offline
I believe what you are looking for are E615PP, E616PP and EET602B L/R.
EAA Technical Counselor #5357
Old 01-09-2009, 03:36 PM
Mike S's Avatar
Senior Curmudgeon
Patrick, thanks for the info.
Under a half hour for a response, nice
Mike Starkey
VAF 909
Rv-10, N210LM.
