Old 01-09-2009, 09:16 AM
Bubblehead's Avatar
Bubblehead Bubblehead is offline
Default Lyc Parts Manual PC-306-16 Needed
Does anyone have a pdf version of the parts manual for a Lyc IO-360 M1B? A link to a web site would be fine too. www.Bomar.biz does not have it listed.
Thanks.
RV-8 180 hp IO-360 N247TD with 10" SkyView!
VAF Donations Made 8/2019 and 12/2019
"Cum omni alio deficiente, ludere mortuis."
(When all else fails, play dead.)
Old 01-09-2009, 10:08 AM
DanG DanG is offline
This site has one for the -M1A. It is PC-306-14. Don't know if it will help.
Dan http://pj260.com/Lycoming/Parts%20Catalogs/
Old 01-09-2009, 10:09 AM
Bubblehead's Avatar
Thanks, Dan. I have that one from another source. It shows a different rocker arm number than I have on my engine. The engine on my RV-8 seems to be a mishmash of stuff. I've replaced the cylinders and want to make sure these rocker arms are correct.
Old 01-09-2009, 12:24 PM
az_gila's Avatar
az_gila az_gila is offline
Smile It should be pretty close to the....
Thanks.
...IO-360-M1A one referenced above.
The FAA TCDS lists this as the only difference.
IO-360-M1A Similar to IO-360-B1E except front inlet fuel injector, prop governor on front of crankcase and retard magneto
IO-360-M1B Similar to IO-360-M1A except has a rear mounted propeller governor and impulse magneto.
ugly long FAA link here
Sounds like the cylinders should be the same when it was shipped from the factory... but who knows after that...
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-09-2009, 01:01 PM
Bubblehead's Avatar
az_zilla - if this were a factory engine I'd be a lot better off. The original builder of the plane put a certified crankcase and crank with old worn out cylinders and accesories with a 200 HP sump and modified intake pipes etc. etc. It's a bit of a cobled up mess. When I pulled the old cylinders off I took the conn rods in to have them checked and found out they had been illegally modified. Two rockers were worn out and I got replacements but I want to make sure they're the right ones.
The M1A parts book shows the rocker p/n should be 17F19357 which is different than what I found on the plane. The document you linked to above was good help though. As you say the M1A and M1B look like they are the same as far as cylinders etc. go.
I got the cylinders from ECi - I think I'll call them.
Old 01-09-2009, 01:46 PM
Bubblehead's Avatar
Default Thank you ECi
I talked to JB are ECi and he had a cross reference to the part numbers. All is well, and I can go back to sleep now!
Old 01-09-2009, 06:06 PM
az_gila's Avatar
Smile A.E.R.O. is a good...
...on-line source for engine part number cross references.
http://www.aeroinstock.com/products/...ail/index.html
I presume you had one of the other rocker part numbers listed on the linked page....
Glad to hear that your parts are OK...
Gil Alexander
