Old 01-08-2009, 05:49 PM
Geico266's Avatar
Geico266 Geico266 is offline
Default Where To Buy 4MM Pulled Rivets?
Is there a VAF member that sells rivets or does anyone knows where to get 4MM domed head aluminum pulled rivets?
Thanks in advance for any leads.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 01-08-2009, 10:00 PM
az_gila's Avatar
az_gila az_gila is offline
Question Larry...could you use...
...5/32 pulled rivets?
4 mm = 0.1576 inches
5/32 = 0.15625 inches
You probably could not drill the holes any closer in tolerance...
5/32 "pop" type rivets are common....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 01-09-2009, 07:04 AM
Geico266's Avatar
I'm helping a guy look this up, I'll pass it on. That should work I would think.
Thanks Gil!
Old 01-10-2009, 07:30 AM
Geico266's Avatar
Well Gil, no joy. The 5/32 rivet shaft is great, but the head size is quite a bit larger for some reason. We are doing a repair and would like the manufaturer's head to match. The manufacturer has a 7,000 rivit minimum order to make them, but we only need 250 tops.
Anyone else have any ideas where to get 4MM pulled rivets?
Old 01-10-2009, 08:45 AM
derLuigi's Avatar
derLuigi derLuigi is offline
Larry,
Gesipa ( gesipa.com ) hat two different rivet head diameters. They're based in europe but do have importers in the US also.
Kind regards,
Mario
Mario from Aachen, Germany
RV-7, emp. done, wings close to being ready for inspection, canoe flipped and parts of the finish kit in just about every room of the house
2019 contribution sent - thanks for this awesome space DR
Old 01-10-2009, 09:23 AM
az_gila's Avatar
Smile Well, you never mentioned....
...the head diameter requirement....
Check out this site, many different makes listed here with head dimensions...
http://www.crawfordproducts.com/index.htm
It seems that about 0.300 is sort of a standard head diameter.
I bet there is also a large range of head diameters for "4 mm" rivets too - it sounds like you need them from a specific manufacturer.
Good luck hunting.
Gil Alexander
Old 01-10-2009, 02:52 PM
Geico266's Avatar
Thanks guys! We're on it!
