Old 01-08-2009, 11:23 AM
rvator51's Avatar
rvator51 rvator51 is offline
Default Arizona engine teardown and inspection
I have a O-360 A1D that has 500 SMOH but has been sitting for 10 years. I had the cylinders overhauled two years ago, but they are still in the boxes.
I was looking for someone to disassemble the case and reassemble with new gaskets/grease and test run.
The one place I contacted wants 6K to disassemble, inspect and reassemble. This seems awfully high to me but I may be out of touch. Does anyone know any place in AZ that will do a teardown and reassembly inspection for a more reasonable price?
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
N53KT RV-6a finished 2018, Flying
N7053L RV-4 Wife's RV
N56KT RV-4 Finishing
Old 01-08-2009, 12:15 PM
Radomir's Avatar
Radomir Radomir is offline
Unfortunately that number you were quoted is the "going rate"... Unless you're doing it yourself (eg assisted by a friend A&P), I'm not sure it's economical to disassemble/reassemble just to put new gaskets..
Radomir
RV-7A sold
Old 01-08-2009, 12:54 PM
yakdriver yakdriver is offline
I would be more concerned with having a reputable shop doing the work rather than the cheapest price. You are the one who has to determine what your life is worth. Don
RV 7 N212MD Flying as of 12/22/2007
Backcountry/TCOW Super Cub flying 03/12/2011
Next project?
Old 01-08-2009, 02:36 PM
rvator51's Avatar
Good point, Don. A safe running engine has to be the number one priority. Hopefully, I can find a reputable shop with good rates too. If not, my C/S prop purchase may be held off for a time.
Regards,
Thomas Velvick
Goodyear, AZ (KGYR)
2020 Donation sent.
Old 01-08-2009, 08:07 PM
I'm speaking with the voice of experience. I got burned on an engine that was supposed to be built by a reputable shop. Luckily I didn't fly it and ended up tearing it back down and re doing it with the help of a good engine builder. Don
Next project?
Old 01-08-2009, 09:08 PM
N131RV N131RV is offline
Default The going rate varies.
A local IA did my removal, teardown, rebuild and reinstall for a flat rate plus parts. Much less than $6000 for the labor.
YMMV
Hangared since 11/23/2011, working on getting airborne again!
Joe Portman
N131RV - RV-7A, IO360A1B6, CS
Rebuilt as TD
Added dual MGL EFIS.
Airborne again at last! 2/21/2009
Elmendorf, TX (28TE)
baron (AT) baron (dot) com
Old 01-08-2009, 09:19 PM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is online now
Default List of AZ Engine Builders
Tom, I got this list from the Eci webpage.
Varga Enterprises, Chandler, AZ 480-963-6936 - Earl White
Aircraft Engine Specialist LLC, Chandler, AZ 480-516-0390 - Greg Starr
Lycon Inc. of Arizona, Mesa, AZ 480-981-0876 - Dean Altman
Legend Aviation, LLC, Prescott, AZ 928-717-1680 - Jay Kerger
Sun Western Flyers, Yuma, AZ 928-726-4715 - Joe Wardle
I have no first hand experience except with Aircraft Engine Specialist LLC. Had questions about my O290 and they were easy to talk to. I didn't buy anything from them and they helped my anyway.
Have you spoken to Robbie Attaway? I know he's an Eci builder and maybe he can assist you working your case/rebuild? I don't know if he would or not, just an idea.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
