Tom,
How do your ailerons align with the wings near the tips, are the top and bottom surface of the ailerons even with the top and bottom surfaces of the wing or at least centered in the wing thickness? Mine (QB also) ended up not centered, one was about 3/16" high above the wing, the other was about 3/32" hign so I re-worked both outer aileron mounting brackets to get the ailerons aligned with the wing. I actually used RV4 brackets because they do not have the pilot holes already drilled. I read somewhere Vans also has these brackets for the RV9 that do NOT have the pilot holes drilled. I never attempted flying the airplane with the ailerons out of alignment but once aligned, the airplane flies hands off, no heavy wings.
Joe Condon
Ankeny, Iowa
RV9A - 647JC - 300 hrs - SOLD 6/23/15
OneX - Under Construction - For Sale
