Rich from Sky-Tec here. I've got to make this quick before Doug Reeves sees I've cracked his forums...
Yes, you can bench check a Sky-Tec. Keep it short, please. That armature is running at some 8,000 RPM. A little load is preferred but an occasional short dry run shouldn't hurt it much.
No Bendix. Never. That's how we roll. Bendix drives were great in 1914 when they were great. Now a days, they aren't so great. Long story.
Sky-Tec started in 1988 with a no-Bendix drive starter. It's all we do and the sole reason we've reached the success we have thanks to all you guys out there. If Bendix drives worked reliably, we'd probably only be selling starters to guys who are sensitive about their weight...aircraft weight that is.
Rich Chiappe
Sky-Tec
800.476.7896
