Originally Posted by vonjet
Its really quite pointless to have all these bill of sales from other transactions. As long as the Factory who made kit recognizes you as the current owner what is the problem? The politics involved in certifying and insuring Experimental aircraft is getting ridiculous.
Hummm....
Are you the one signing the 8130-12 stating "I certify the aircraft identified in Section II above was fabricate and assembled by ______???Name of Person(s)???______ for my (their) education or recreation. I (we) have records to support this statement and will make them available to the FAA upon request." Did the former owners hire someone to build the parts?
YOU are the one responsible for providing these names, NOT the factory that manufactured the parts. You mention all you received was a handwritten bill of sale but hopefully you got some sort of build log as well. Worse case scenario, you may find that your Lancair becomes a very expensive static display.
Not so pointless if you step back and look at the big picture.
Just in case no one has told you yet, you may not be eligible for a repairman's certificate either.
Getting the info pack from the EAA is a step in the right direction, there's LOTS of good info on their site about buying a kit from individuals as well.
What you should read if you are considering buying an experimental aircraft or partially completed kit.
