01-04-2009, 01:27 PM
Newbie Help Please! I drove bad rivets
Ok,
I drove a couple bad rivets... drilled them out and the next two I drove were worse... then I got a figure 8 and a big hole now...
you can see more at my build log:
http://www.mykitlog.com/users/displa...og=68364&row=1
I did a search here and found this thread:
http://www.vansairforce.com/communit...ight=bad+rivet
I've ordered some AD5 rivets from spruce, so I could just drill them to take the AD5 rivets... but I'm thinking about just drilling a couple new #30's two rivet diameters out from the existing mess and putting a third equadistant between the two mishapen holes.
If I do latter should I try and fill the mishappen holes or just let them sit?
Any advice is appreciated.
Tom
I Timothy 2:1-2 I urge, then, first of all, that requests, prayers, intercession and thanksgiving be made for everyone-- for kings and all those in authority, that we may live peaceful and quiet lives in all godliness and holiness.
I Thesalonians 4:11-12 Make it your ambition to lead a quiet life, to mind your own business and to work with your hands, just as we told you, so that your daily life may win the respect of outsiders and so that you will not be dependent on anybody.
01-04-2009, 01:39 PM
If you do this, be aware that there are basic rules about minimum rivet pitch (distance between rivets) that generally need to be followed. In general, you need 3x rivet diameter between rivets. This means you'd need 3/8" for the #30 rivets. Cleaveland has a great pull-out chart in their catalog that provides important fastener specs.
Also, bent over rivets are most often the result of too long of a rivet. Save yourself a lot of grief now and buy a $15.00 rivet cutter. That way you can cut down those called out in Van's drawings that are a little too big. I waited until after I started my fuselage before I did this. Wish I had known to do this sooner--it would have save me many a headache.
Also, be aware that -5's will be tougher to set than the -4s.
I'd recommend you check with Van's regarding your options.
Hope this helps. Good luck.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
01-04-2009, 02:34 PM
been here awhile
We've all been there...done that......
Ok,
It happens.
Tom
Adding 2-3 new holes and rivets would be a very satisfactory solution, just comply with the standard edge distance rules. No need to fill the old holes...they just add character.
Build on!
01-04-2009, 02:43 PM
I'm sure you realize I left out all the cussing and knashing of teeth that was happening with the bad rivets and then worse...
I like to be good at what I do... building is teaching me more about myself than about building...
So it sounds like I was on the right track for the repair... though I guess its 3 rivet diameters not two....
Tom
01-04-2009, 04:28 PM
If you decide to go the -5 route, make sure your gun is up to it. If you are using a 2X gun, you may run into serious problems trying to get the rivets to set. You'll most likely need to borrow someone's 3X to get the job done properly.
PP ASEL-IA
RV-10 N728TT - Flying!
WAR EAGLE!
01-04-2009, 04:37 PM
Note that the 3 rivet diameters...
Tom
...is a hole edge to hole edge distance.
The specifications would call it 0.500 inch minimum rivet spacing and measure it from hole center to hole center. It's also a greater dimension for flat head rivets.
More details here....
http://www.rvproject.com/MIL-R-47196A_MI.pdf
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
01-04-2009, 06:02 PM
Rivet drilling how-to
Tom,
On the outside chance you need to drill out any more rivets prior to completing your airplane, here's a decent rivet drilling how-to (IMHO).
Mike Cencula
RV-7A (fuselage)
www.our7a.com
Betcha my pile-o-scrap is bigger than your pile-o-scrap.
01-04-2009, 06:32 PM
Formal training is recommended
Riveting is not hard but there are some basic techniques that are better taught in a hands-on environment than trying to acquire as you build your airplane. You are obviously very conscientious but is difficult to do a good job without training. You will not feel the anxiety after you get a little experience and approach each task carefully with a concept of what the risks are and how to deal with discrepancies.
Bob Axsom
01-05-2009, 02:53 PM
Tungsten
I have found that a Tungsten Bar is a great help ! I didnt get one until late into my wings, I wish I had one from the start. The best $100 tool I have spent so far. PM me or do a search for Tungsten if you need contacted info. Looking good so far.
Jamie lee
Brisbane, Australia
RV7A - Now Flying.
0-360,carb,catto 3 blade.
VH-XJL
01-05-2009, 03:28 PM
Riveting Practice
I attended one of the sheetmetal workshops at Oshkosh and the instructor's closing advice helped a lot:
"Buy some cheap aluminum or beg some scrap from another builder.
Lay out some rivet lines with appropriate edge distance, etc. and start pounding and squeezing rivets. Drive about 200 rivets and repair all the bad ones. Once you do that you'll be comfortable with your tools and your technique. Now you're ready to tackle your project." I made a lot of mistakes on the scrap, got better and then tackled both of Van's practice kits. When the kit arrived I was ready to open the boxes and get to work.
I'll also second Jamie's comment about tungsten bucking bars: I own two (Avery's 6001 and 6004). The 6004 now handles 90% of my riveting and the 6001 handles the other 10%. The iron bucking bars are collecting dust in my toolbox. Way more control with the tungsten steel bars and they can fit in really tight spaces.
Good luck,
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
